New tank emblems
Old Dec 25, 2012 | 10:35 AM
Fatbobiron's Avatar
Fatbobiron
Default New tank emblems
I'm going to change my stock Pewter tank emblems on my street glide to a set of chrome tank emblems
They are the same size.......any advice on an easy way to get the old emblems off?
I'm thinking if a little heat and some Adhesive remover.
I'm thinking ill simply use a crayon to outline the emblem now and then place the new one in the exact same spot on the tank.
Any advice?
Old Jan 4, 2013 | 05:54 PM
Bagger71's Avatar
Bagger71
Just saw your post.
If you have not done it already I used 25lb. test fishing string. Put some leather work gloves on and wrap the string around a couple fingers on each hand. Slip the string under the emblem on one end then work it back & fourth as you pull. You might go through a couple pieces of string but it doesn't scratch the tank & no heat needed. You will also maintain the shape of your original emblems if you want to use them on something else or give/ sale them. The double sided backing tape they use comes off very easy. HTH
Old Jan 4, 2013 | 08:26 PM
UltraNutZ's Avatar
UltraNutZ
woulda never thought of that one! good pointer there Bagger71
Old Jan 5, 2013 | 12:27 PM
Fatbobiron's Avatar
Fatbobiron
Originally Posted by Bagger71
Just saw your post.
Awesome tip.
Thanks.
I've been a little under the weather for a few days and haven't changed the emblems yet.
I'm going to do exactly what you suggested.
I'll update when I get this done.
Thanks again!
Old Jan 5, 2013 | 03:08 PM
londonking's Avatar
londonking
pm sent
mrhappy999
Dec 28, 2014 12:35 AM
WiscoKid
General Topics/Tech Tips
Jul 11, 2014 12:37 PM
tstammer
Aug 9, 2009 01:07 AM
ricoman
Dec 23, 2007 04:09 AM
bensonjv
Sep 7, 2006 06:37 PM
