2013 Switchback
Old Nov 3, 2013 | 05:57 AM
Tahaa's Avatar
Tahaa
2nd Gear
Default 2013 Switchback
My 2013 Switchback seems to rev power or surge up and down on it's own when started, any idea's why? I shut it off and restart and it seems to work, but it's kind of scary when it does this.
Old Nov 3, 2013 | 06:02 AM
checkers's Avatar
checkers
I don't know how much "rev" you are getting, but some is normal. It may help if when you turn on ignition, wait a few seconds before cranking engine. This allows the ECM to monitor sensors before engine is started. It is a habit you can get in to. Also when it revs after a start, let idle settle before engaging into gear.
Old Nov 3, 2013 | 06:06 AM
Tahaa's Avatar
Tahaa
2nd Gear
Thanks so much.. It's almost like I'm reving the throttle like a gremlin in is there messing with me, you are right I think I try to start it too soon after I switch it on..
Old Nov 3, 2013 | 06:40 AM
Iceman24's Avatar
Iceman24
Also, when you shut-down the bike...let it idle @ normal RPM a bit before hitting the stop switch. The ECM is sensitive and can fluctuate your idle settings a bit if you're not starting & stopping the bike properly.
Old Nov 3, 2013 | 08:44 AM
Tahaa's Avatar
Tahaa
2nd Gear
Thanks so much I will follow your advice
Old Jul 20, 2014 | 06:32 AM
Tahaa's Avatar
Tahaa
2nd Gear
Default Vance and Hines Fuelpak
Harley service is saying a V & H Fuekpak can screw up your engine, anyone have this problem?
trackadaptor
Apr 9, 2021 08:46 AM
SA315B
Apr 9, 2017 10:38 PM
Teroy
Sep 29, 2015 11:22 AM
thehueg
Aug 7, 2008 03:22 PM
johnica
Jun 18, 2008 06:34 PM
