Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
To Rake or not to Rake
Old Jul 30, 2025 | 05:27 AM
  #61
smitty901's Avatar
smitty901
Originally Posted by Racepres
Since I distrust Slugs..Longer tubes, for me. ..but, I have other "projects" that will gobble up "spare" parts!!
The short slugs are not like the extension once in common use. Example This crash totaled a Trike and the pick up truck broke the forks off. Destroyed the frame and CNC tree. The 2 inch slugs were prefect condition.
If you purchase quality products, nothing to be concerned about.
Old Jul 31, 2025 | 07:16 AM
  #62
Racepres's Avatar
Racepres
^^^ Good Info..thank You.
Now, For my Next Act.. I am going to put a Pair of Bent Fork Tubes, on my 94 Sportster/Velorex, Rig.. Bent so very close to Identical, I did Not do Much "shaping", and should Move my Front axle forward about 3 Inches..(a Guess right now) if turned 180 from the "damaged" position..
To My Eye, look better than the Ez-Steer...Now...Will it work!!!! Maybe I start a Thread if it does...But...For Now...to Rake? or Not to Rake???
Yes...I get Crazy Ideas... sometimes they actually Work!!
Old Jul 31, 2025 | 03:52 PM
  #63
smitty901's Avatar
smitty901
Can I have your information. I would lie to take out a life insurance police in your name .
Rake or leading link both work ,depends on your goals.
Old Aug 1, 2025 | 02:33 PM
  #64
Racepres's Avatar
Racepres
Sure...Already have two rigs with Raked Trees, and One with Leading link, (Ural) the Ural is the Least Liked, handling!
Now, The "bent" forks...Are working right now.. Not completely done with new setup..but..Coming Nicely...Thanks for the concern!!
Old Aug 3, 2025 | 06:35 AM
  #65
Racepres's Avatar
Racepres
Working Fine. Spent a few Hours yesterday giving Rides at a Special Olympics.. plus ride over to town and back..Keeping an eys that it don't bend More (monitor ride height) but..so Far..I like it!!
Can see the Bend of Fork, not as severe as it looks with tube removed...but, enough to change Geometry...plenty!
Darnit...it was kinda Muddy getting to where the Olympics was at.. may need to give er a Bath!!! And yes, I had the fender on, Gonna do some tweaking now..
For my Act...I'm going to experiment with "offset". Plan is a Touring Harley, with a Conventional (probably a Good Ole Duoglide) front end.. should offset the Tubes about 2 or maybe even 3 Inches!! Again...moving axle forward in relation to Neck...ie Reduce Trail numbers!!
Unfortunately, No Touring Rubbermount bike on the Farm, Currently!!
Old Aug 14, 2025 | 08:34 PM
  #66
Racepres's Avatar
Racepres
I can't believe there are No Comments about my "Bent Forks" here in the "rake or Not rake" thread!!
evilrider
Aug 15, 2016 08:13 PM
agiffey
Jun 15, 2012 12:58 AM
pavin
Nov 22, 2011 07:20 PM
CountryPunk
Jul 10, 2009 09:44 AM
20NightTrain03
Apr 9, 2009 03:22 PM
