Cycle Rama CR 570-2 and fp3
Old Feb 13, 2020 | 05:49 PM
Ropestringer's Avatar
Ropestringer
Default Cycle Rama CR 570-2 and fp3
Hello all, I have a Vance & Hines FP3 and I've been looking at bolt in cams. I think the CR 570-2's would be my best option. The problem is that they're not listed as supported cams on the FP3 app. Is anyone running this combo and if so, how did it work? What cam did you select? I'm hoping the FP3 works well but if not then I'll be buying a Power Vision.
Gregg
Old Feb 14, 2020 | 06:05 PM
MyFavRk's Avatar
MyFavRk
Would probably be a good idea to give V&H a call and see if their working on that cam set up , Bryan is a member here and may respond to your post .
Old Feb 14, 2020 | 06:13 PM
Ropestringer
Thanks, I did email Bryan this morning and he promptly responded. I should be good to go.
Gregg
Old Feb 14, 2020 | 07:47 PM
MyFavRk's Avatar
MyFavRk
Great , glad to hear you got it sorted out !
Old Dec 8, 2022 | 03:47 AM
Hueyhog's Avatar
Hueyhog
6th Gear
Gregg
how did the cr 570-2's work with the fp3? I'm thinking of doing the same thing.
Old Dec 8, 2022 | 05:28 AM
Ropestringer
I ended up going with the CR575's and stage 2 headwork so I used PV instead of the FP3.
Gregg
Old Dec 8, 2022 | 10:05 AM
Hueyhog's Avatar
Hueyhog
6th Gear
Gregg
Ok, thank you.
Old Dec 8, 2022 | 02:02 PM
Hueyhog's Avatar
Hueyhog
6th Gear
Ok, thank you.
just an update for anyone looking for this awnser, V&H FP3 does have maps for the CR570-2. It's not on their site yet but if you call they can upload to your bike.
Just my opinion, i think the FP3 is great for the full range of stage 1. I also believe when you move to a stage 2 or 3 you should go dyno to properly have all the parameters set correctly, if your gonna spend that kinda of money it should be done right.
I personally will be using the FP3 upload on my stage 2 just long enough to complete the brake-in period just to save some money on buying a new tunner.
Wishing everyone a safe and Merry Christmas!
TSD
Oct 16, 2016 07:52 PM
Ncdyna925
Jan 12, 2014 05:46 PM
krebsrob
Jun 5, 2010 09:15 PM
BIGDADI
Jun 1, 2010 09:36 PM
ncdan
Dec 2, 2009 07:49 AM
