VIN Error code 13 FXDC
Old Dec 30, 2024 | 03:36 PM
Moonshine9's Avatar
Moonshine9
Stage I
Default VIN Error code 13 FXDC
I have a 2013 FXDC, I have had an FP3 tuner on it for a couple of years now. I was riding it one night, once I stopped and shut the bike off. When I started it back the speedometer no longer reads speed and mileage doesn't go up. The lights work and it still shows the mileage. It will also chatter the relay sometimes when I try to start it like the battery is dead and throw a VIN Error code. I cleaned the speedometer sensor in the transmission just to make sure and no issues there. The bike has 8,100 miles on it. Is this an issue with the FuelPak 3 tuner? Or would a loose or raw wire cause this? Thank you in advance.
Old Dec 30, 2024 | 05:24 PM
smitty901's Avatar
smitty901
Likely bad head unit. Mileage is store in ECM then sent to odometer.
Pull main fuse let it sit a few minutes put fuse back
Old Dec 30, 2024 | 06:18 PM
CoolBreeze3646's Avatar
CoolBreeze3646
1. How old is the battery?
2. May want to get it load tested.
3. Voltage may show good; however, amps (CCA) may be way low.
4. Batteries can have weird effects on electronics.
5. As above, pull main fuse, put a good charge on the battery, put fuse back in and see what happens.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
HAPPY-JACK
Sep 12, 2022 04:09 PM
mgb1
Feb 16, 2019 06:00 AM
mgb1
General Topics/Tech Tips
Nov 13, 2018 10:30 PM
Sonoma67a
Dec 27, 2017 12:33 AM
05dynaman
Mar 7, 2014 09:19 PM
