starter/battery probs
Old May 4, 2008 | 03:32 PM
dalston34's Avatar
dalston34
Stage II
Default starter/battery probs
My road king classic,euro spec,battery failed after no useage over the winter.
I am unable to start it using my other bike as the power source,I get the lights and the usual warning lightswhen Iswitch on,but no response at all from the starter.
There isn't even a flicker from the lights when the start button is pressed.
When I turn the ignition switch to on after turning the key on,the indicators flash about 6 times,rapidly.
Any ideas,the nearest dealership to me is 60miles away,not easy to get to and Harley in the area I live is a rare as hens teeth.
Old May 4, 2008 | 03:51 PM
rjrivero's Avatar
rjrivero
Default RE: starter/battery probs
Do you have a factory alarm on this Road King? Sounds like the alarm is set.
Old May 5, 2008 | 03:10 AM
dalston34's Avatar
dalston34
Stage II
yes it has a factory alarm,if the previous owner has set a code would removing the battery affect the set up when I replace it after such a long interval.
The alarm on the euro spec bike is automatic and cannot be altered,other than a transport mode(HDI,Model).
Brian
Jeff Loyd
Jun 18, 2018 09:15 AM
Pastor Kevin
Oct 24, 2017 08:03 PM
Bathog
Sep 23, 2012 07:10 AM
bboy57
Aug 16, 2012 01:14 AM
zenwarrior
Sep 28, 2007 10:20 AM
