No engine light
Old Mar 26, 2006 | 03:55 PM
snipit's Avatar
snipit
Default No engine light
I have an '01 RK EFI just did a a partial removal of the gas tank to replace the throttle and idle cables. Everything went back together without any problems EXCEPT now when I flip the "run" switch on the engine light doesn't come on and I don't get the familiar humming of the fuel pump kicking in. I've rechecked all connectors and checked all fuses (with test light) everything seems to be fine.
Any help would be GREATLY appreciated. Fuel gage and all lights are working.
Thx
Snip
Old Mar 26, 2006 | 09:26 PM
fxdxsteve's Avatar
fxdxsteve
Default RE: No engine light
did you check all the fuses?
d'oh
I should have paid attention to your post sorry
Old Mar 26, 2006 | 09:46 PM
BigGeorge's Avatar
BigGeorge
Snipit, I dont want to sound dumb here but is your bike equipped with a "TIP OVER" switch? If somehow the switch got tripped, you need to cycle the ignition "ON- OFF- ON to reset it.........BG
Old Mar 26, 2006 | 10:02 PM
snipit's Avatar
snipit
thx bigGeorge but I tried that too
Old Mar 26, 2006 | 10:58 PM
fxdxsteve's Avatar
fxdxsteve
go back to the stuff under the tank something may have come loose under the tank where you can't see
Old Mar 26, 2006 | 11:34 PM
BigGeorge's Avatar
BigGeorge
Snipit, another posibility. Maybe the "run switch" on the handle bar went bad. Have you checked the switch with a contunity tester? (the battery should be disconnected when you test this way).........BG
Old Mar 27, 2006 | 12:44 PM
fxstcguy98's Avatar
fxstcguy98
I'm pretty sure my bike has a ground wire on the front tank bolt, check to see if that is connected.
Old Mar 27, 2006 | 02:28 PM
Woodyheritage's Avatar
Woodyheritage
You may want to see if you shorted/crimped a wire in your handgrips/switches when you replaced the cables. A short in the start/run switch will kill fuel pump and ignition without blowing a fuse.
Good luck,
Woody
Old Mar 28, 2006 | 09:52 AM
snipit's Avatar
snipit
THX everybody for the suggestions. Woody was real close. The right handlebar controls were still disconnected inside the headlamp nacelle. Thx Woody you da man
Old Mar 28, 2006 | 11:07 AM
Woodyheritage
Glad to be a little help.
Enjoy the ride
97EGC
Aug 25, 2015 11:46 PM
AJ_Rider
Electrical/Lighting/Alarm
May 12, 2014 10:02 AM
cananderson33
Jun 9, 2011 06:16 AM
DLX
Jan 4, 2007 01:11 PM
snipit
Exhaust System Topics
Mar 26, 2006 02:45 PM
