Ping
Old Jul 14, 2006 | 01:04 AM
Ballz's Avatar
Ballz
Default Ping
I just got about 600 miles on my new big bore....HTCC heads and HTCC 1550 pistons, 257 cams, high output download in the ECM. I noticed tonight that when I put it under a load, it starts to ping pretty good. I am running 91 octane fuel. I'm not talking about lugging it, I mean putting it under a load at about 70-75 mph by going ahead and twisting on the throttle. Will this pinging go away when I get the custom fuel map done on the PCIII?
Old Jul 14, 2006 | 02:12 AM
sonar_chris's Avatar
sonar_chris
Default RE: Ping
most likely it will go away with the added fuel, however, you could have to much total timeing and that is causing it to ping.
Chris
Old Jul 14, 2006 | 02:53 AM
PhilM's Avatar
PhilM
Default RE: Ping
Chris is right. Too much timing will cause it to ping. Low octane fuel in a high compression engine will cause detination.
"Usually".... if it happens near anytime (hot, warm, cold), it's too much timing advance. If it seems to occur only after the engine is heat soaked, it's more than likely detination ~ fuel igniting from hot carbon, a red hot plug tip, compression etc.
Pinging will also occur if you have too much compression for the cams. I'm not sure where the sweet spot is for 257's but I doubt it's cmpression related with that hot of a cam. That typically happens with much milder cams.
A good PC tuner should be able to help you get it iron out.
Old Jul 14, 2006 | 11:13 AM
Ballz's Avatar
Ballz
Default RE: Ping
Thanks fellas, that's what I wanted to hear. Going in for a tune next week.
JDG1172
Engine Mechanical Topics
21
May 7, 2017 01:41 PM
kylebryan
Sep 9, 2015 09:58 AM
wwillen
Jul 4, 2015 09:51 PM
load97
13
Sep 18, 2013 10:50 AM
TakeNoCrap
Exhaust System Topics
15
May 16, 2008 07:38 PM
