Power Vision Information Thread
Old Apr 2, 2012 | 05:10 PM
  #2121
djhrln's Avatar
djhrln
135 c = 275 f
Old Apr 2, 2012 | 05:47 PM
  #2122
Heatwave's Avatar
Heatwave
Member
Originally Posted by djhrln
135 c = 275 f
I think this is your answer on the 135.
Old Apr 2, 2012 | 06:02 PM
  #2123
Teardrop's Avatar
Teardrop
Originally Posted by iclick
If you're looking for fuel economy in the cruise range you can have both power and mileage in one tune. I see no rational reason to tune for economy anywhere else. The only drawback to increased mileage is some corresponding increase in heat and part-throttle response. I find both side-effects to be minimal on my '07 even when running at stoich.
If you're doing Basic tuning (closed-loop) you can't tune for WOT anyway, so I would use the same values that are present in the open-loop areas of the FM tune, then set Lambda as near 1.0 as you're willing to go for the closed-loop portion. For AFR bikes, set AFR values to 14.6 and Closed Loop Bias to 450-780 (lower being leaner).
I have a second tune which is the same as the normal tune except all AFR cells are at 13.0. This is for emergencies and I need all the cooling I can get, like for a summer bout of gridlock traffic that doesn't move for long periods.
I have looked everywhere but am unable to find the section to set Closed Loop Bias to 450-780. Where do I go to adjust CLB?
Old Apr 2, 2012 | 06:20 PM
  #2124
djhrln's Avatar
djhrln
expand fuel, then expand closed loop.
Old Apr 2, 2012 | 06:36 PM
  #2125
Heatwave's Avatar
Heatwave
Member
If your bike is a 2010, it doesn't have a closed loop bias.
Old Apr 3, 2012 | 02:27 PM
  #2126
iclick's Avatar
iclick
Originally Posted by TedMan
Thanks, IClick and Heatwave. IClick, I did exactly as you suggested a week ago and got about 7-10 deg. difference in temp. Country riding 55-60 mph. I will also try Heatwave's method and see how that turns out.
That jibes with my tests, as I ran about 7° cooler at 13.5 compared to 14.6 when I had my PCV-AT and a hardware switch. That isn't much, IMO, but the difference may be more pronounced at lower speeds. I.e., temperature may rise at a slower rate, but I haven't tested under those conditions.
Gas mileage will be several MPG higher at 14.6, as when I accidentally ran my rich PV tune (13.0) for a long day's ride my mileage was around 6mpg lower, and I saw no difference in ET and little in OT for that day vs. the next. I didn't notice much difference in throttle response either. I think the cooling effects of lowering AFR's is somewhat exaggerated based on my experience with this bike.
Old Apr 3, 2012 | 02:44 PM
  #2127
iclick's Avatar
iclick
CLB is only on AFR bikes, and like Heatwave said you don't have this table. You would set Lambda to .981-1.02 to stay in closed-loop, which achieves the same effect. I only mentioned CLB in my reply to you in an effort to avoid confusion for riders of older bikes like mine.
Old Apr 3, 2012 | 02:46 PM
  #2128
Heatwave's Avatar
Heatwave
Member
CLB is only on AFR bikes, and like Heatwave said you don't have this table. You would set Lambda to .931-1.02 to stay in closed-loop, which achieves the same effect.
I believe the Closed Loop range is .981 - 1.02
Old Apr 3, 2012 | 03:18 PM
  #2129
bohica48's Avatar
bohica48
Quick question: When people say they adjust the AFR (Lambda in my case) to Closed Loop for the "cruise range," what is the typical cruise range? Is it 2400 - 3400 and 30 MAP to 70 MAP, for example? Thanks for any advice here.
TedMan
What I did to establish my cruise range on the map was adding the Vehicle Speed Sensor (VSS) to my gauges when logging data. I would then look at the log file in excel and note what Kpa value was at certain steady speeds, I varied my speed using different gears and cruise control to simulate different driving scenarios. From this I was able to set CL in the cruise range. Hope this helps.....
Old Apr 3, 2012 | 03:30 PM
  #2130
ahern25's Avatar
ahern25
Quick question. Maybe I missed it througout the thread but does the PV have a feature that adjust the lag on the fly by wire system used in the 08 and up touring models? Im running a PCV but it does nothing for the lag in the throttle body. I was considering the Vance and Hines new throttle pak which claims to adjust the lag. Would like to stick to Dyno Jet.
