Power Vision Information Thread
and stayed with Jamies original MAP. WOW bike runs alot better,,and I cant really tell from just my ears,, but I don't know how it could run better,,
I will do some logging runs and see if Jamie can see something,,but other than that,,I am quite content.
I will get the visor for it and mount it on my bars this summer just to educate myself,,
but I am impressed with this unit!
TedMan
If just looking at tuning outside of the close loop area, nice idea to find what the motor likes. Are you setting your AFR down in the 13.* range to start with, and then adding VE as necessary?
In closed loop range, I'd prefer to put my priority on VE first, then alter spark as needed
The PV allows me to make modest revisions to a well performing map that are unique to the way I ride. I would not consider this a reasonable approach unless I was already starting with a well performing map that essentially has the WOT part of the map relatively "squared away".
For example my engine is a 110 but the displacement of my map is 114.5. By raising the displacement, it allowed me to increase spark advance in both cyls and then data log to see if I created any knock events by using the knock sensor.
Once I adjusted the fuel map by adding fuel in any cells where knock occurred, I was able to create a higher performance map with even crisper throttle response.
Ordered V&H Pro Pipe, Pro Billet Air Cleaner, and Power Vision from Fuel Moto. Good price, prompt shipment and delivery. Installed myself, not without some challenges - the space to bolt the pipe onto the bracket attached to the transmission is real tight.
The Power Vision is cool. I've never had another tuner so nothing to compare with but this is what I wanted, something to flash the ECM and not reside on the bike. Fuel Moto supplied tune went in, and the difference is noticeable. Bike runs very well, I will have to watch out for speeding tickets. Roll on the throttle at 70 to pass on the interstate and you're going 85 in a hurry. Need to ride more to see how mpg fares but so far looks to be around 40.
Only changes I have made to the tune: modify the speedo factor by about 1% to get it to read a little closer to my GPS. It was 3-4 mph off, now it is 1-2 off which is OK with me. Other change, EIMTS was set off in the tune, I set it on. Nothing else yet but I am still looking and trying to figure out what might be good for the bike.
Question: any reason that EIMTS should be off? Does it screw anything up? Bike came from the dealer with it off. Just wondering.
Been lurking on this forum for a while. The wealth of info is amazing, I have learned a lot. Thanks to all of you who do research and share your results. Thanks to Fuel Moto for doing a great job in pre-sales consulting with me, and in processing the order correctly and promptly.
If you're doing Basic tuning (closed-loop) you can't tune for WOT anyway, so I would use the same values that are present in the open-loop areas of the FM tune, then set Lambda as near 1.0 as you're willing to go for the closed-loop portion. For AFR bikes, set AFR values to 14.6 and Closed Loop Bias to 450-780 (lower being leaner).
I have a second tune which is the same as the normal tune except all AFR cells are at 13.0. This is for emergencies and I need all the cooling I can get, like for a summer bout of gridlock traffic that doesn't move for long periods.
You say you were running 325° "in a short while," but under what conditions? If that's in traffic, how long did it take to get that high and how slow was the traffic moving?
