Power Vision Information Thread
Old Apr 1, 2012 | 08:38 AM
  #2091
GoPro Steevo's Avatar
GoPro Steevo
Originally Posted by Fierofly
After you do your tune with log tuner is it a good idea to use the smooth option on the whole Spark Advance Tables and the VE Tables?
Fierofly,
The answers to your questions...
Spark Advance: NEVER. Remember, Log Tuning can never add timing, it only has the ability to reduce timing where spark knock occurs. If you are starting with a map from FuelMoto, I would leave the spark tables alone.
VE Tables: Never smooth the WHOLE table. You can select small areas of cells to smooth, but especially if you have no decel issues, leave the far left column (20kpa) as it is. And also be careful in the idle rpm range. Smoothing the whole table may result in a richer idle, but leaner top end. I prefer to do manual smoothing, making changes to intermediate cells, while keeping the highs "high" and the lows "low".
Old Apr 1, 2012 | 06:12 PM
  #2092
Teardrop's Avatar
Teardrop
Originally Posted by GotMy11SG
Fierofly,
I agree. Once I got the PV figured out I have been running some log tunes. I was letting it adjust the timing along with the VE tables and after about 6 runs my bike was actually running worse than it was with the canned map from FM. I took the copy of the map that Jamie provided and copied my new VE tables to that map then smoothed the entire VE table both front and rear. My bike has never run this smooth even when new. I am now playing with the AFR/Lambda table. I am looking for best power with fuel economy second and I think I am just about there.
My bike has stock head pipe with cat removed, 3.5 Jackpot mufflers, SE stage 1 breather and SE 204 cams.
Old Apr 1, 2012 | 07:22 PM
  #2093
Fierofly's Avatar
Fierofly
[quote=Teardrop;9606497]I agree. Once I got the PV figured out I have been running some log tunes. I was letting it adjust the timing along with the VE tables and after about 6 runs my bike was actually running worse than it was with the canned map from FM.
Now thats a relief. I thought I was the only one with that proplem. After about 5 tuning runs, bike runs terriable and I'd just start over from scratch. The 2 or third seemed to always be the best and I couldn't figure out what I was doing wrong. This is my fourth attempt. So your thinking with the stock OX sensors I should tune VE only. My problem is the map I got from Jamie is actually for a Woods 555 cam cause he didn't have one for a S&S 570. I've got no popping at all and it keeps setting a rich code till about the 2nd tune run. I'm worried about the spark advance not being correct for the S&S cam.
Old Apr 1, 2012 | 07:29 PM
  #2094
Fierofly's Avatar
Fierofly
For smoothing if I've got a 54.7 (1000rpm)then a 74.0 (1125rpm)then a 55.3 (1250rpm)in the 0 throttle column should I smooth just these three numbers or manually enter a middle number like 55 in these kind of cases
Old Apr 1, 2012 | 07:43 PM
  #2095
Teardrop's Avatar
Teardrop
What I did was click on the upper most box to the left of the 20 kpa box and right above the 750 rpm box. This will highlight the entire field. I then hit the smooth function and smoothed the entire VE table.
Old Apr 1, 2012 | 07:45 PM
  #2096
Teardrop's Avatar
Teardrop
[quote=Fierofly;9606806]
Jamie had a map for my setup so I believe the timing is correct but for your setup it might not be. I would give them a call maybe they can stear you in the right direction.
Old Apr 2, 2012 | 02:14 AM
  #2097
Sam2010's Avatar
Sam2010
VE number is maxed out at 127 is that correct? To get more room on VE number you increase the cubic inch number? My fuel moto map is set at 96.7 cubic inch.
What is a acceptable increment to increase the cubic inch number?
From 3000 to 4500 rpm and 50 to 100 kpa is looking like its going to need more room this is the general area thats also pulling timing.
My new exhaust pipe has both size o2 bungs I am starting to consider the pro auto tune but first I need to learn more about it.
Old Apr 2, 2012 | 07:10 AM
  #2098
Heatwave's Avatar
Heatwave
Member
Here's how I use the knock sensing capability of the Log Tuner.When I have cells that show "knock" after a data run, instead of lowering the spark I raise the VE. Since generally the knock is occuring outside of a closed loop region, the O2 sensors are not capable of calculating what the VE should be in that region.
First I don't bother screwing with any knock readings lower than .5. And then for each knock reading from .5-1.5 I raise the VE in that cell by 1%. From 1.5-2.5 I raise it another 1% and so. Then I look at the map in the region that I just adjusted and smooth out the readings so they are gradually higher as the Kpa's and RPMs increase. Then I ride and log.
Generally one or 2 datalogs and tuning using this approach will get the knock sensor readings below .5. Once the readings are generally gone or minor, I turn the knock sensor off and then you will feel a significant increase in seat power and smoothness. That's my approach to using the knock sensor readings in the log tuner.
The only time I go back and reduce the spark advance is if a cell is already at 127.5 and can't be raised any higher, then I go back and lower the spark advance by a digit until the knock sensor reads less than .5. There are only 2-3 cells on my map at this high of a level.
I would be interested in other viewpoints on my tuning approach regarding knock sensor readings. Its seems to be working very nicely for me in terms of smoother and more powerful performance from the seat.
Old Apr 2, 2012 | 08:00 AM
  #2099
ColoSpgsMark's Avatar
ColoSpgsMark
[QUOTE=Heatwave;9608468]
If just looking at tuning outside of the close loop area, nice idea to find what the motor likes. Are you setting your AFR down in the 13.* range to start with, and then adding VE as necessary?
In closed loop range, I'd prefer to put my priority on VE first, then alter spark as needed
Old Apr 2, 2012 | 08:57 AM
  #2100
Linville Lion's Avatar
Linville Lion
What is the best AFR setting for idle? I was in stop and go traffic yesterday (mostly stop) for Martinsville. Ambient temperature was 70F. My ET seemed to climb faster than I remember last year. It got to 325F in a very short while. Oil Temp stayed below 230F so I was okay but it surprised me. I did add fuel to the idle range over the winter. It is set to 13.8 AFR in the idle part of the map. I thought extra fuel would cool the engine. I am wondering if extra fuel generated more heat. What think thee?
