Power Vision Information Thread
Old Mar 22, 2012 | 05:28 AM
  #2001
SGLarry's Avatar
SGLarry
Originally Posted by iclick
The map I got from FM originally had 780, which translates into about 14.43:1. Here's a chart from the FM site. I'm a bit confused, as according to this chart 14.68 is 500mv while the TTS manual states that 450mv produces this AFR.
Yeah, the info out ther about closed loop bias voltage seems to differ slightly.....Here is some more info that states something different about voltage. It says 500mv translates to 14.6:1 and that 700mv would be closer to 14.3:1.
http://tuneyourharley.com/biketech/c...l-map-revealed
Anyway, the bike is running well thanks to all the info and help here. :-)
Old Mar 22, 2012 | 06:52 AM
  #2002
JustDennis's Avatar
JustDennis
Originally Posted by Fierofly
So if I'm useing 2 Maps, one for tuning with the required items turned off and one for normal riding. I shouldn't use the log I got from the tune map to tune both the tune map and the run map??
OK, so you have a tuning version and a riding version which are versions of the same base map. One has AFR and switches set for tuning and the other set for normal riding - Yes applying the changes to both of those map is fine. Actually that is what I do if I am only making 1 set of changes.
Old Mar 22, 2012 | 06:57 AM
  #2003
JustDennis's Avatar
JustDennis
Originally Posted by kranky
I am seeing a lot of "requires pro level" in my PV manual. I do not have
a Bias table in my version. I'm thinking i need the auto tune to have the
"pro level" functionality.
"Pro level" just refers to the tables that are available for display and adjustment in the WinPV software. Go to Setup > Options and change your User Level to "Pro". You don't have to have wideband sensors to use pro level functions in WinPV. Everyone should set the software to pro level
Old Mar 22, 2012 | 07:01 AM
  #2004
JustDennis's Avatar
JustDennis
Originally Posted by TedMan
Thanks again, Iclick. The pinging I mentioned was intermittent and only accelerating up a hill where load goes up. Flat ground never pinged, no matter how hot. I have heard that the SE 204 can be difficult to tune, but don't know why. I will watch KR more closely next time. Won't get a chance to do another ride until Sunday. Will report back.
TedMan
I'm curious. Are you still running a closed-loop map (AFR at 14.6) and reaching these temps? If so, change those closed-loop AFR cells from 14.6 to 13.8 and test again. Iclick reports he doesn't see any difference but I run open loop on my bike and it runs about 15 degrees cooler.
Old Mar 22, 2012 | 07:08 AM
  #2005
JustDennis's Avatar
JustDennis
450mv would translate to 14.68 AFR or 1.00 Lamba, 730mv would translate to 14.62 AFR or .996 Lamba. The bias is a way to slightly offset the entire AFR table. Changing from 450mv to 730mv would give you an offset of .06 AFR richer on all your AFRs. The stock O2 sensors have a narrow bandwidth so you shouldn't go much more than that.
Old Mar 22, 2012 | 08:15 AM
  #2006
TedMan's Avatar
TedMan
Default Hot
Thanks JD. I am running closed loop from low RPM through 3500 and up to but not including 70 MAP, with a Lambda of 0.981, as I recall. I think this equals 14.32 AFR. I used a base map for my set-up from FM, but after tuning (in Basic Mode) I did not change any of the AFR's. I will lower the lambda to 0.945 (13.8 AFR) and give it a go. Thanks for the advice. I'll let you know how it works out.
TedMan
Old Mar 22, 2012 | 08:22 AM
  #2007
TedMan's Avatar
TedMan
Originally Posted by Lonewolf176
It's common to see the 204's idle there. Only way to change that is to change when the ecm reads the map value. That's why on some tuning devices you choose your base map based on the camshaft. You shouldn't have any issues at 40 kpa.
I think that those temps are fairly normal. I data log quite a few and will normally see temps of 250-275 running down the highway. The bigger the engine the higher it will be. My only suggestion is to remove some timing in that area and see what happens. It will also help with your pinging.
Thanks, Lonewolf, for the perspective. I am going to lower my Lambda and watch KR very closely for specific problem spots. Will report back.
TedMan
Old Mar 22, 2012 | 09:37 AM
  #2008
jmeiers's Avatar
jmeiers
Thumbs up
I didn't know any non-touring bike had TBW. A friend with a '12 Dyna Switchback has cables.
I'm sorry, you are right. I was mixing it up in my head with the CAN tuning. The Dyna's didn't switch to CAN until 2012.
Old Mar 22, 2012 | 11:09 AM
  #2009
iclick's Avatar
iclick
Mines an "09 tbw and the map that Fuel Moto sent loaded on the PV has the "closed loop" under fuel set at 700 volts also. I thinkk it depends on the map strategy that FM uses to build the map?
Now I'm really confused. Your '09 has a CLB table? I thought only cable bikes ('07) and only a few '08 calibrations had one and all others were adjustable by changing the Lambda value between .98 and 1.02. Can anyone clear this up?
Old Mar 22, 2012 | 11:19 AM
  #2010
iclick's Avatar
iclick
I would let the PV tune-out the detonation, but be wary of false knock events reported by the ECM. Mine does this at one point on the front cylinder only and will show knock regardless of the amount of advance you put in. If it keeps pulling out spark advance at the same amount on a sporadic basis I would put the old values in and just let the knock sensor deal with it in its own way.
In my case it will retard usually not more than 2° for a few seconds at the same point on the graph (~60KPA @ 2200-2500 RPM) but only sporadically, then will revert to normal. I haven't seen any PE spark adjustments come from this odd behavior, but Jamie told me to just leave it alone and don't let the LT tune spark-advance in that area. I now feel like spark-advance is okay and I no longer move the spark tables over to WinPV in the last step of the tuning process.
