Power Vision Information Thread
Old Oct 4, 2012 | 10:13 AM
  #3261
JeffJA's Avatar
JeffJA
Originally Posted by stro1965
Earlier in the thread I read that someone said yes to that question. I did.
Is that JUST for the auto tune moddified maps?
Old Oct 4, 2012 | 11:10 AM
  #3262
WetSider's Avatar
WetSider
As a general rule, it is appropriate to "reset learned values" any time you are loading a map that has revised VEs.
Old Oct 4, 2012 | 11:33 AM
  #3263
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by tdkkart
So where do the "fuel used" and mpg values come from??
I have to assume that the amount of fuel used is based on injector duty cycle, which I assume is also included in the VE calculations, not??
So if one is off they'd all be off by an equal amount.
It appears, based off of GPS readings that my speedo is dead on, or VERY close, depending on how much you believe GPS readings.
In theory you may need to recalibrate the PV Trip Center if you change your build or tune, however it is not the other way around as Trip Center is only a estimated/displayed value and has nothing to do with the tune itself.
Let me try to explain....
VE is the predicted airflow model of the engine, it is used along with the lookup tables to determine fuel delivery requirements, while PV Trip Center is simply a channel that displays "estimated" MPG etc.. like the distance to empty on your odometer (how accurate is that?) The Trip Center is based on algorithms used and stored by the speedo cluster. The Fuel used and MPG in the PV trip center are simply displayed values based on outputs, they are not ECM inputs.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Oct 4, 2012 | 12:31 PM
  #3264
JeffJA's Avatar
JeffJA
Crap, i hit "no" when loading the new auto tuned map, can i just reflash it and the. Just hit "yes"?
Old Oct 4, 2012 | 01:03 PM
  #3265
tdkkart's Avatar
tdkkart
I realize this, the fuel used number is an output. However, when I have to add a percentage to that number in order to correct it, that means that whereever that number came from was inaccurate, which also means every other place that number was used is potentially screwed up too.
I know that injector outputs can be all over the map, has Fuel Moto ever played with the OEM Harley injectors to see how consistent they are??
Old Oct 4, 2012 | 01:47 PM
  #3266
stro1965's Avatar
stro1965
I would think so.
Old Oct 4, 2012 | 02:54 PM
  #3267
Delta's Avatar
Delta
1. Yes you can do it that way.
2. You can also, from the Main Menu of the PV:
Select Vehicle Tools/Select Reset Trims
Old Oct 4, 2012 | 02:58 PM
  #3268
Delta's Avatar
Delta
And/or if you have changed anything in the AFR/Lambda fueling tables.
Old Oct 4, 2012 | 03:56 PM
  #3269
JeffJA's Avatar
JeffJA
and i'm guessing thoes change when you're auto tuning?
Old Oct 4, 2012 | 04:07 PM
  #3270
Delta's Avatar
Delta
I don't believe so. When you begin the autotune process the AFR/Lambda values are changed globally. When you export the values learned the AFR/Lambda values are changed back to the original values; (haven't changed) and, you can ride and let the learned values accumulate. You have to physically change the values in the AFR/Lambda Fuel Table. For example, you are using a value of .981 in the cruise area of the table. You want to try and get a little better fuel economy and change those values to .986. You would then have to reset the trim.
