Power Vision Information Thread
Old Oct 16, 2012 | 08:22 AM
  #3361
bohica48's Avatar
bohica48
Jim,
I would not think that by updating your original tune to autotune would change any of the tune tables, I did not see that with mine. As you stated comparing both in WinPV should give an indication of changed parameters, if it doesn't then there may be an issue with the firmware for your specific strategy.....
Old Oct 16, 2012 | 11:33 AM
  #3362
cruiser85257's Avatar
cruiser85257
Originally Posted by Teche
Sorry Delta, I have been slacking with this thread. No I am pretty sure it was my fault, so I did not press any warranty fixes. I am still having crazy decel popping. I have since replaced the exhaust gaskets to eliminate leaks as the problem. Dynojet has been very helpful and has sent me a few maps using my AT results+their fixes trying to fix the popping. Still no luck though. I dont mind it, I just want to make sure its not hurting anything. Im getting like 30 to 31 MPG now, so that has gone down. Probably all that extra fuel from the popping. I am still not comfortable enough to tweak anything myself. I keep comparing the maps that dynojet sends just to see what they are tweaking to try and learn.
Your throttle is closed when your decelerating and popping. So it would not be the cause of your poor fuel mileage.
Old Oct 17, 2012 | 08:00 PM
  #3363
JeffJA's Avatar
JeffJA
i seem to be getting pretty crappy fuel mileage too, only getting about 32-33MPG, i have no decel popping at all...so im not sure why the poor mileage
Old Oct 19, 2012 | 07:42 AM
  #3364
Gozzie's Avatar
Gozzie
Default Timing
I read alot about pinging and timing problems. Doesnt the power vision auto correct for this. I'm ditching my thundermax for the same exact reason.
Gozzie
Old Oct 19, 2012 | 09:15 AM
  #3365
Delta's Avatar
Delta
The PV will not auto correct the spark tables. You can make the corrections yourself by doing a datarun and then use the logtuner software and WinPV. It will only remove timing from knock activity present. I don't know of any tuners that will advance timing.
Old Oct 19, 2012 | 07:44 PM
  #3366
tdkkart's Avatar
tdkkart
The PV does retain the factory ecms knock detection which the Thundermax does not. The PV's datalogging ability allows you to see where the pinhing is happening so you can tune it out manually.
There is some auto adjustment available with the PV, talk with a rep and they can help you with it.
Old Oct 20, 2012 | 05:24 AM
  #3367
William The Red's Avatar
William The Red
Default Autotune will ajust timing
Here is a copy of my timing from 2000 rps to 4500 front cyl. The rear only has few areas and I am still getting knock in the front. I am to the point of thinking about going back to stock. Are cams and heads from F/M
0.00 1.50 0.00 0.00 2.00 0.00 0.00 0.00 0.00 0.00
2.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
1.10 5.50 1.50 1.50 0.00 1.34 2.00 0.00 1.29 1.75
10.75 2.00 2.00 3.50 5.80 3.92 4.94 3.43 0.00 2.93
4.50 2.50 4.00 2.58 3.81 11.82 10.15 8.63 9.95 8.52
8.08 0.00 0.00 2.00 4.33 4.62 7.23 6.79 8.36 7.73
0.00 2.50 0.00 0.00 0.00 0.00 0.00 0.00 3.39 5.10
0.00 0.00 0.00 0.00 0.00 0.00 2.00 0.00 0.00 0.00
Old Oct 20, 2012 | 08:59 AM
  #3368
Teardrop's Avatar
Teardrop
I was getting a lot of knock activity but one thing I have come to realize is I need to have the entire VE tables dialed in before I make any adjustments to the map FM provided me. I hardly ever get any knock activity from my bike and I am confident that with a few more auto tuning runs I will be able to tuine it out 100%.
Old Oct 20, 2012 | 12:10 PM
  #3369
tdkkart's Avatar
tdkkart
Well that's not your timing, your timing advance numbers would be in the 20-45ish range, this has to be maybe the delta numbers between your current map and your original maybe?? If so, these numbers aren't obscenely out of line depending on what your starting point was.
No reason to get discouraged. You've got a Fuel Moto build, have you asked them to help?? I'd be glad to look at the numbers if you can send me the actual files and some data log info.
Old Oct 20, 2012 | 08:57 PM
  #3370
switzead's Avatar
switzead
I got answer back from FM on this question and they state that the numbers are an average of spark events per the number hits in that cell and suggested I take 1 degree of timing out of this area and run more logs to see where it stands.
Originally Posted by switzead
After running the log tune and importing into the PVV. What do the numbers in the Spark Knock Front and Rear actually telling me. For example does a 1 in the cell mean there was 1 degree of retard in that range or 1 sec/min of 8 degree retard in that range? The tune process does not change the spark tables, maybe thats because my numbers are so small, but I am not sure. AND I am thinking you need to go into the spark table and remove some timing in these areas to stop the knock but I am unsure how much, mainly based on the fact that I dont know what the numbers actually mean.
