Power Vision Information Thread
Old Nov 23, 2012 | 07:24 PM
  #3501
ColoSpgsMark's Avatar
ColoSpgsMark
OTF, it's pretty common to hit the 127.5 limit with good mods. Your VE profiles look similar to mine. What I've read about the CDE/EGR tuning is that you should only touch those after you have your VE's dialed in. That way you're not chasing two variables at the same time. When I got my initial tune from FM, some of the cells were maxed and the PV adjusted my CI and VE's accordingly (103 to 110). After changing my mufflers, CE's maxed again in a couple of cells and I'm now bumped to 115 and it seems to be enough. Also, where you're hitting 127.5 on your tables are higher than CDE is supposed to influence (>60 KPa), so it won't help to bring those down. In summary, get your VE's dialed in first using the normal sample/correct approach and then once that is done, test the CDE changes to see what impact they have.
Old Nov 24, 2012 | 12:49 AM
  #3502
stailjim61's Avatar
stailjim61
Originally Posted by Delta
I tried this a few months ago https://www.hdforums.com/forum/10448428-post3356.html The easiest way to explain it would be to look for the valleys or troughs in the VE 3D map. If the valley is at 3000 rpms go to the CDE table and increase the number that is at 3000 rpms. You'll have to experiment with it. I went from a value of 42 to 55 and the trough began to disappear. Keep notes on what you changed and how much difference it made. I did one area at a time and was pleased with the results. I ran out of good testing weather and will continue further with it in the spring. I think I read somewhere that it will affect those areas 60kpa and below. When you get to the point that you are visually satisfied that the valley has filled in you can start to smooth if you desire.
I don't know if this is the correct way, but it worked for me. Still waiting for improved documentation.
It will affect beyond 60 kPa but minimally. The intent of messing with the CD tables is to try to affect a smoother running engine at the lower rpm's and loads. That's where the problems usually surface, mostly to the position and lack of depth of the tip of the 02 sensors. Harleys don't really have an optimal location to mount the sensors to work effectively down low. To get the sensors to work nice they'd have to mounted in a position where they'd look like crap...there just isn't much room to work with the bends, frame rails, etc. If someone wasn't that concerned about looks or concealing the sensors they can be mounted to work much better though. I think just getting more of the sensor tip in the exhaust flow would be a nice improvement, not only in dialing in the ve's but overall running when tuning runs are done. It just depends on how far and how close someone really wants to get it dialed in.
Once you get it to where you're happy with the ve's I wouldn't even worry about smoothing the charts appearance. The ECM will just override your changes and put it right back to where the 02 sensors are reporting. If that's what the bike is telling you it likes there's no sense changing it.
Old Nov 25, 2012 | 07:19 AM
  #3503
bohica48's Avatar
bohica48
On my last AT run I selected "Log Start" to create a log to use with the PV Log Tuner software. I wanted to be able to see hit counts in each of the cells and the cells i missed. In the PV Log Tuner software when I open select "Open Log(s)" it appears it's trying to open the log but only for a brief moment, nothing loads. I've used the Log Tuner without any problems prior to the new AT firmware updates, anyone had this problem or know whats going on?
Never mind, I had a senior moment, forgot to select "Calc Tune".
Old Nov 25, 2012 | 08:47 AM
  #3504
Sam2010's Avatar
Sam2010
thanks for follow up.
Old Nov 25, 2012 | 12:12 PM
  #3505
fxdc rider's Avatar
fxdc rider
so im trying to download the new firmware update for the pv that has the auto tune and it keeps popping up saying that it cant open the file because it doesnt know what program to open it under. tried opening it under win pv and log tunner as well and still says not compatable? any help would be apreciated
Old Nov 25, 2012 | 03:09 PM
  #3506
Delta's Avatar
Delta
Are you using the PV Update Client when you are trying to do this? Should be in your Power Vision program folder.
Old Nov 25, 2012 | 04:20 PM
  #3507
fxdc rider's Avatar
fxdc rider
i dont know how to access that. when i go into the pv program folder under my computer(windows xp) the only folder i have is "original tunes" nothing else
Old Nov 25, 2012 | 04:28 PM
  #3508
fxdc rider's Avatar
fxdc rider
oops just figured out how to get to the update client folder, thanks
Old Nov 25, 2012 | 04:43 PM
  #3509
Delta's Avatar
Delta
In the lower left hand corner hit the windows icon. Then select All Programs/Power Vision/PV Update Client
Make sure your PV is plugged into the computer when you do this.
Old Nov 25, 2012 | 09:46 PM
  #3510
fxdc rider's Avatar
fxdc rider
Thanks guys, finally got it download and update. now to get some logs in tomorow before it rains for the next 5 days
