Power Vision Information Thread
If those 12 or 15 cells are within your normal riding area you need to get them calibrated. otherwise why even waste your time, just take it to a dyno tuner. If you're having trouble filling in the cells start by focusing on a smaller area. Take some blue painters tape and cover everything below 3000 RPM's and everything to the right of 25% TP. Go out and practice filling in that area the best you can. After a while you'll get the hang of hitting the cells.
The only time I wouldn't worry about those "uncalibrated" cells is if they are way outside of your typical riding style. Meaning they're way out to the right, or they're in the higher RPM's you don't ride in. If any of those 12 or 15 cells are inside cells and you didn't collect enough data you need to AT until you hit them.
You should be hitting 15% throttle at 1000 RPM's, which covers 1000 to 1250 RPM's. It can be tough at first but with practice it can be done. Then your line should go to the right and down from there. Meaning the higher the RPM the further out to the right you need to be filling in squares. With a TP based cal there will be cells in the upper right corner and lower left corner that you probably won't hit. That's okay. You'll never ride in those cells anyway. Everything within those corners needs to be filled in, to include 500 RPM's BEYOND where you normally ride, at a minimum.
I installed a set of Woods TW-222's last week and received a map for my setup form Fuelmoto. I had my previous tune (before cams) dialed in to well below 5% changes from tune to tune.
I have completed 6 autotune runs with the cams and I have gotten the changes down to -0% average and 9% max change. The bike is running good with no decel popping.
Thanks
Thanks
So I need to re-run AT after I make a timing change using LT?
Timing numbers flow well reading left to right, but have a hiccup when reading up and down in the 70-80 kpa column. Here are the new timing maps after the LT worked on them. These were made from logs ran while out west and loaded in varying riding conditions. I am not sure if this map would be pertinent for where I live in Louisiana because of the big change in elevation, heat, humidity.
I haven't talked to the dyno guy to see why it is locked, but I presume he believes he owns the "tune", I'm just allowed to use it.
Using the NB sensors, and AT Basic we are achieving an accurate tune that supports our mods, but still at the (EPA mandated) lean 14.6 AFR ratio within that cruise zone. If the bike is running strong and the engine temps are reasonable than this all one needs.
However, if looking to push engine temps down while still achieving high performance and smooth power across the power band, then one needs to add fuel.. hence the need to implement WB sensors in order to accurately tune the bike down into the 12.7 - 13.1 AFR range. You may get this, but I am saying it more to confirm my own understanding.
To all you experts out there, who are much smarter than I am on this, please correct me if I am wrong on the basic premise above.
My approach for my fairly conservative, "Day trip touring" type riding style here in New England is to get my bike running smooth, strong and cool. I'm already getting adequate power and smoothness with the NB sensors, but I would still like to see my engine temps slightly cooler. Yesterday in low 90'F heat I was up towards 265'F at the highest, but I'd love to have that down below 240'F for the most part. If I can get that by dropping a few more bucks on my bike, I don't mind.
But, I'm still learning, and right now it's much more towards just getting it right and understanding the details of the PV with AT-Basic. Once I get this dialed in I'll evaluate moving on to the AT-Pro tuning.
Again, guys, if I am off base on this please correct me, as I am slowly absorbing this process and repeating what I THINK to be correct here, primarily to confirm my current understanding. Comments solicited?
I've got a very basic "Stage 1" bike. Air Cleaner/Powervision/Slip-on pipes. The bike has stock cams, and stock everything else. The goal for my bike is to give it the right amount of fuel to do 2 things;
1. Give it the best performance across the power curve to support general riding and day-trip touring. (no racing)
2. Give it the right amount of fuel to help with a cooler running engine.
I've polled FuelMoto and techs from Dynojet that I met up at laconia bike week, as well as a few respected members of our group here at HDforums.
The total consensus across everyone, was that the WB kit was not going to provide any big benefit for my basic Stage 1 bike. This would be different if you go to cams and other engine upgrades where you are significantly changing the timing and internals of the engine. But, your basic Stage 1 daily rider, not going to help.
I just wanted to close out this piece of the discussion I had with various folks. Basic message was get the VEs correct with AutoTune and enjoy the ride. The Dynojet team did agree that bringing the AF Ratio (on my 07 EGC bike) down to 14.2 would be a good move for both performance and some cooling. They also built me a 13.9 open loop version and said they were both going to give me a strong performance.
I've tried both and can't really see much difference between either of them. I have been monitoring engine temperature with both my <cEwan oil temp guage as well as the PV engine temp and am getting these results which everyone agrees I should be pleased with.
On nice cool New England days of about 75-80'F I get about 200'F average on the oil temp guage while cruising and about 225'F on the engine temp guage. The ET may increase to 250'F during stop and go traffic.
On hot New England days with 90'F air temps, I am getting about 215'F oil temp and up to 260'F ET while riding along. The bike still feels fine.
So, that's my report out. I can share the tables that we're built if anyone wants them, but remember I have an 07 bike that works on the AFR and Closed Loop Bias table, not the KPA of the TBW bikes.
