Power Vision Information Thread
Old Aug 21, 2013 | 12:15 AM
  #5251
itsahog's Avatar
itsahog
I bought and am insatlling the PV with Pro Tuner. I have a 09 Ultra, and I have a question. Behind the left side cover, where the diagnostic plug in is suppose to be, I have two options to plug into. One is open ended, and the other is right below the fuse box plugged into a sleeve. Which do I use to plug PV into? THX
Old Aug 21, 2013 | 07:46 AM
  #5252
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
The one that it fits.
The one plugged into the sleeve is where you would plug in a siren for the security system, if you have one.
Old Aug 21, 2013 | 07:56 AM
  #5253
oldhippie's Avatar
oldhippie
it's open ended and has a protective rubber cap. Square in shape.
Also, go through all the videos on the Dynajet web site.
http://www.dynojet.com/powervision/p....aspx#ytplayer
Old Aug 21, 2013 | 08:22 AM
  #5254
XFXDX's Avatar
XFXDX
Originally Posted by Uncle Chester
You need O2 sensors for the auto tune basic.
Thought so, thanks. Went home after posting that, apparently my Vision doesn't even have the AT feature loaded on it... Oh well.
Old Aug 21, 2013 | 08:36 AM
  #5255
oldhippie's Avatar
oldhippie
when you load the PowerVision software and plug the PV into your computer with a USB cord, the very first thing you do is update the PV Client software.
Go to lower left of your computer: All Programs> Powervision> PV Update Client and then walk through the update process. It is easy. It will figure out what you have and then lead you through the update if there are any.
AT is on the 2nd screen once you click >Program Vehicle.
Old Aug 21, 2013 | 12:16 PM
  #5256
stailjim61's Avatar
stailjim61
Originally Posted by Oilsmoke
Adaptive learning kicks in right? I am close than I ride all over that place I guess I am mood driven I have a few cell over 5 but most are well under 2
So is ..977 good place to set closed loop area I cruise in?
Thx
Oilsmoke
Give it 2 tanks of varying riding conditions to learn. The integrators will be doing their things for the short term trims right away but give a couple tanks to build a profile AF table. If you're running a closed loop tune you may feel it run a little better after a couple tanks. Or, if you got lucky and your VE's are close you may not feel it. Either way, it's learning and building a profile. If you're concerned about how far off your VE's are you could run a datalog showing your CLI %'s. If they're between 95% and 105% you'll be fine.
That should put you around 14.35 at cruise. Should be fine. The cruise areas usually tune up pretty nice so if you wanted to go richer I wouldn't hesitate to go open loop. I wouldn't go any richer and keep it in closed loop though. The efficiency of the sensors starts to degrade as you get to the flat spot of the slope.
Old Aug 21, 2013 | 12:24 PM
  #5257
stailjim61's Avatar
stailjim61
Originally Posted by fullautomike
OK after the 6th datalog timing adjusted tune, no more spark knock! I rode the hell out of my bike, even went to a BIG bike night and stuck in traffic with head temps up to 325*....no spark knock!
OK when you say do 2 more VE runs, use AT or LT? One step at a time for me, when I get this done we'll "talk" about the next move.
Thanks!
Any input?
Mike
Use AT for the VE's initially. Then use LT for timing. Then when timing is good make 1 or 2 final VE runs using LT. You always want to do things in the order of VE ...Timing...VE. My choice to do the final VE calibrations using LT is because LT is datalogging without any manipulations to timing, ie: reducing by 4*. There's nothing that says you MUST do it this way. You'd probably still be fine finalizing with AT. Just make sure you do it. Timing changes can make subtle changes to your VE's so it needs to be done to bring the VE's in line with your timing.
Old Aug 21, 2013 | 01:53 PM
  #5258
peg20's Avatar
peg20
Has anybody started creating a library of maps? In particular, if anyone has a auto-tuned map for a 2013 fatboy with Arlen Ness big sucker and V&H BSS, could they post or PM the VE, AFR and timing tables for me? I'd like to compare with the stock and supplied maps to see how much variation people have seen in VE, the variation of AFR values people use and where they differ and how aggressive you can get on timing as some kind of guide before I start pushing it myself.
Thanks in advance
Old Aug 21, 2013 | 06:49 PM
  #5259
Delta's Avatar
Delta
I believe that lambda values below 0.977 will automatically go to open loop. Though I don't know why anyone would use 0.976. I know the efficiency of the sensors on the AFR bikes that relied on Closed Loop Bias were greatly effected by how far away from the center value you went. Don't remember the numbers.
If anyone knows if the new and the old style sensors degrade the same way could they post. About all I do to check my sensors is datalog from time to time and check the O2 voltage (currently between 0.82 - 1.72) Not sure what this means but it shows that are switching on and off.
Old Aug 21, 2013 | 07:46 PM
  #5260
oldhippie's Avatar
oldhippie
So I tried to do another AT this evening, and I had the most unusual results.
The AT seemed to go normally, with the exception that the green map screen of cells was displaying in a different differently. I figured it must have somehow gotten put in a different mode, so I "clicked" through the modes and found the normal mode that shows the "hits".
So the rest of the At went well and I exported learned cells, and saved the tune to the PV. Brought up WinPV and did a compare from the previous tune and all of the cells I didn't hit, we're all showing 10% delta (this is normally zero for me previously)
The other thing I noticed immediately was that the displacement of the new tune showed 107.4ci. I'd love to have 107 but I don't!
Any input? looks like this AT was a wasted of good gas.
