Power Vision Information Thread
If you just had it dyno tuned did this issue not show up during tuning? I would not run AT after having it dyno tuned assuming that was done properly.
ok thanks LA dog appreciate it
I have read from some threads that after autotune engine should run cooler 220+. My normal operating temp is around 380 after autotune. Just want to find out if this is normal. What is your normal operating temperature? If not normal, what could cause it to run hot?
Thank you
mike
When you did Autotunes, did you successfuly get through the entire rpm range and iteratively finally get to a set of values within 5% or less through that range? Also as you did go through the autotunes did the ATs want to scale up and if you allowed the scale up, what final displacement value did you land on and were you finally able to do an AT without a request to continue to scale higher?
I'd be interested in what your AFR lambda settings are for that rpm range also?
I do agree with LAdog that this should have shown during the dyno, and all of the settings you now have in your PV should be the result of that dynotune.
The reason I ask about the scaling up thing, is when FuelMoto built my engine, they did an initial Dyno and found my fuel pump system to be failing at about 3500 rpm. The system just couldn't deliver anymore fuel at wot/high rpm, yet at lower rpms it felt fine. My only indication prior to the dynotune Jaime did was that the ATs kept wanting to scale up for the higher rpm numbers.
I've attached my dyno sheet for the example of what it looked like. Note the AFR just continues to gradually get leaner as the revs move beyond 3Krpm.
Makes me wonder if you don't have something similar.
Or, another thought, what are you using for a throttle body and injectors? Have those been upgraded? I wonder if they are able to deliver the fuel you need with that build? (but still that should have shown when you had a dynotune done)
see my dyno sheet attached.
[EDIT] - scratch that, i see the note in the dyno chart about your SE 50mm TB. What's funny is even with my mild stage1 I see my puny 3.9 injectors hit up to 100% duty cycle on WOT / high Kpa. there is no way they'd support any type of increased performance.
Thank you
If you think your VE's are dialed in accurately, try running a richer AFR across the board and go for a test spin- see if temps are lower. it won't hurt anything to try this as a quick down-n-dirty test to see if running lean especially at idle / cruise was the cause. I've attached an example of a rich open-loop AFR table. I run this on my bike with So Cal 90's / 100's weather. I don't get over 280 with town stop-n-go and sitting at lights.
Also if you run richer AFR in the leftmost two columns 20,27 from 1250 rpm and up it will help with quieting decel popping. AT does not help with that either. you can use the exact values in the attached AFR table for a test.
lastly- if your VE's are not dialed in that well then making AFR table adjustments may not help much. the ECM can only calculate the AFR values correctly if VE's are set correctly. in many cases a good performance tuner will richen up VE's in a tune instead of richening up the AFR table. From what I've been learning about tuning, most of the time the VE's are set up too lean with the canned tune maps and also left too lean in load areas with the basic auto-tune products.
Yes I run AT basic with narrow band 02 since I only have stage 1 mods. I still need to run AT a few more times to dial it in. Once I get that done, will try to richen AFR using the values from your table to test.
Thank you much! Aloha!
You can also auto tune too much. typically you only need a few AT runs to get what you can out of it. What someone like Jamie / FM does is put in some manual changes to the tune based on personal experience and knowledge.
When you say you have high temps is this with auto-tune turned on or disabled? I can fully see this happening with AT turned on. I personally don't even use AT, waste of time trying to properly tune with narrow band O2. I tried it once and all it did was kill my performance and raise ET's by leaning out the VE's I had set richer. That's ok if I want uber-economy but eh this aint no Prius brah ;p
Thank you
I also have several systems that try to address the heat issues inherent with my 120r motor.
I would be concerned if my head temps was in excess of 300 degrees F!!
Roger
