Power Vision Information Thread
Old Sep 19, 2015 | 11:15 AM
  #7641
PTAG's Avatar
PTAG
Originally Posted by E8USMCRET
On a non technical note. I ordered my PV from Fuel Moto and should get it in a few days. They said that the handlebar mount won't work on my 1 1/4 Burly apes. Does anyone have a source for a mount that will work on those thicker bars? Thanks.
Ram handle bar mounts work up to 1/4 inch.
I used this (fits up to 1 1/4 bars):
Amazon.com : RAM Zinc Coated U-Bolt Mounting Base with 1 inch Ball : Sports & Outdoors Amazon.com : RAM Zinc Coated U-Bolt Mounting Base with 1 inch Ball : Sports & Outdoors
You then but the other pieces separate:
Amazon.com: Ram Mount Composite Double Socket Arm for 1-Inch Ball Bases: GPS & Navigation Amazon.com: Ram Mount Composite Double Socket Arm for 1-Inch Ball Bases: GPS & Navigation
Amazon.com: Ram Mount 2 x 1.7 Inches Base with 1-Inch Ball that Contains the Universal AMPs Hole Pattern for the Garmin zumo/TomTom Rider/Urban Rider: GPS & Navigation Amazon.com: Ram Mount 2 x 1.7 Inches Base with 1-Inch Ball that Contains the Universal AMPs Hole Pattern for the Garmin zumo/TomTom Rider/Urban Rider: GPS & Navigation
You can also get all the parts in one package if you look around.
Old Sep 19, 2015 | 12:31 PM
  #7642
Yookdew's Avatar
Yookdew
Originally Posted by tdkkart
You're really chasing a non-issue anyway, you're rarely, if ever, at actual 0% throttle, especially at 1750 or 2000 rpm, and even if you were it most likely won't cause any sort of rideability issue. I haven't played with throttle percentages lately, I'm not sure you can even get to an actual 0% throttle reading??
I'd agree that if it is a true reading it's most likely caused by reversion in those short pipes.
I ran several autotunes on a different map prior to this and ran into the same issue. The problem I ended up having was backfiring and popping during deceleration. I'm guessing as I continued to cap that area, the autotune leaned it up causing the issue. I only know the basics of tuning so I'm not sure how to deal with this decel area with the VE's going up so high.
I believe it is probably reversion also with the short pipes plus i removed the original baffles and installed Big City Thunder baffles which are much more free flowing.
I plan to get out in a little while and run a datalog that I can post in the thread. Hopefully you guys can tell exactly what the issue is by looking at the datalog and can help me come up with a solution.
Thanks for the input and help so far.
Old Sep 19, 2015 | 03:11 PM
  #7643
Yookdew's Avatar
Yookdew
Originally Posted by whittlebeast
I need a data log that has
MAP
RPM
PW front and rear
O2 sensor volts front and rear
TPS
AFF front and rear
CLI front and rear
Spark retard front and rear
VSS
It is set up from the PV Logging fields screen
Then log for about 45 min ride from the backroads, not just highway
Andy
Attached is a datalog I just ran. It looks to me like some of the information you requested didn't populate so I may have set up some of the datalog setting wrong. If this is the case let me know and I will try to correct and do another datalog. The powervision has some of the sensors listed multiple ways so I may have selected some of the wrong ones.
Thanks
File Type: csv
Old Sep 20, 2015 | 02:33 PM
  #7644
whittlebeast's Avatar
whittlebeast
Yep, you missed a couple of critical things.
It does appear that something is messed up down low.
see
http://www.nbs-stl.com/HarleyTuning/...tle%20Bust.png
The plot on the right should be generally a straight line.
Here is an example of a well tuned bike. It happens to be running Dynojet Target Tune.
http://www.nbs-stl.com/HarleyTuning/...%20vs%20DC.png
Andy
Old Sep 20, 2015 | 09:17 PM
  #7645
Teardrop's Avatar
Teardrop
How many people have installed the target tune on there bikes? I have the PV with Auto tune pro and was wondering if I would see much difference.
Old Sep 21, 2015 | 06:14 PM
  #7646
shorty07ultra's Avatar
shorty07ultra
I have the pro model also on an 07 ultra. I had the map very close but never seemed smooth. Put the target tune on and took about five minutes and the engine turns smoother and seems to pull better. Very happy with my purchase.
Old Sep 21, 2015 | 08:49 PM
  #7647
scooterbum46's Avatar
scooterbum46
Using the PV on a 2015 Tri-Glide (103TC).. The channels offered for monitoring includes "Baro", but I get nothing displayed when I set it up.... I'd swear I was getting a reading when I had the PV on the 2014 Ultra Ltd.... I have never seen a resource that lists the data channels that the Delphi ECM outputs; I spent quite a bit of time searching the 'net recently.. Does anyone have info on whether the "Baro" data channel (I presume it wold be ambient barometric pressure..) is or is not present on the 2015's?
Old Sep 21, 2015 | 10:20 PM
  #7648
Teardrop's Avatar
Teardrop
Sounds good. Did you get a different map when you went with Target Tune?
Old Sep 22, 2015 | 06:08 AM
  #7649
shorty07ultra
Yes they converted the map to a target tune enabled map I flashed it and took off on a ride. Been riding for three weeks and very happy with the refinements that the ecu is making now on the fly.
Old Sep 22, 2015 | 08:47 AM
  #7650
oldhippie's Avatar
oldhippie
What are you guys with the 07s running for engine builds? I've been considering the Target Tune, and it's probably just a matter of time and I'll get it, but the bike is running so well, that I think it will refine and smooth things a bit as opposed to generate more power. Or at least more seat of the pants power.
