Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
no Andy, first time I've seen that link so thanks. I really need to learn more about using scatter plots to assist with tuning- although the TT has made things immensely easier, there are still some inaccuracies with target afr and a lot of big peaks / valleys with the VE tables- I find myself now looking to learn more about using CDE to smooth the tables, and how to further get VE to be very accurate with target AFRs. Although I'm at a bit of a disadvantage until I get my new 4.9 injectors installed- I'm hitting well over 80% max IDC everywhere with the 3.9's so I'm sure that is causing some issue.
well this thread has been unusually quiet
hope everyone is out ridin and enjoyin- I've got a new 50mm TB and 4.9 SE injectors to install, then do the TT tune process all over again.
Rode yesterday and the bike felt great. Noticed fuel economy was a little low. I opened my tune from the power vision and became confused. I had 4 base line pvt's. I loaded tune from bike and saved to slot. Looked and the same as the last baseline tune that was in it. Looks like I am full open loop? Sent mac an email but in case he is busy thought I would let someone else see it. https://www.dropbox.com/s/0q81cr18kk...-1-16.pvt?dl=0
was this modified by narrow band basic auto tuning, or AT Pro auto tuning?
your AFR table is solid "13.0" for the entire table- yes that will be open loop and is typically only good for tuning with AT PRO, if you ride that you will of course have lower MPG since the low load and cruise areas are richer than they need to be. closed loop AFR's with narrow band sensors will be 14.9 to 14.3 in your tune file. that will typically be the light load and cruise areas.
your spark advance tables are quite advanced, which is good for power, but your VE's seem a bit low and rather jaggy- quite lean in some areas as well like decel and mid rpm high load. this could be giving you some ping under load. but the ecm will detect and pull timing so not optimal but no worries.
email Mac he'll get you straightened out. when running auto tune be sure to exclude 30kpa for the minimum map in the auto tune settings- if you auto tune 30kpa and under it will only lean out the VEs
not sure what you mean by "four baseline pvt's" - do you mean you have 4 different saved auto tune session files - e.g. "000001.pvt" etc?
I know 13.0 is open and any lambda below .976 or 14.3 is open. Thought maybe he did on purpose at first. Some people believe it or not love full open loop. I wouldn't hence my inquiry. I spoke with the tuner. He overlooked changing the lambda table back after running the tune session. He ran 4 tunes where he changed timing ,ve tables, and throttle blade from macs map as a base cal. The timing is actually about optimal he said as when he advanced another 2° it lost power so he went back to the base cal. The ve tables with my pipe will be unperfect. He used wideband on dyno so the 13.0 was the dyno setting. Thankfully I caught it as I seemed to be using a lot of fuel Monday. Bike ran great though. Minimal decel pop and should be better after loading this cal and adap fuel relearns. I spoke with some on HTT and they say the short pipes are hard to tune and will have some spikes.
I will not auto tune this as it will just want to lean it out per mac. My afr is really good here on the chart. The dyno operator leaned it out already from macs base cal to not be too rich. Here is the cal with afr changed back. https://www.dropbox.com/s/a1ay07qdw7...29-16.pvt?dl=0
