Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
slydog- now what did they claim to "tune" exactly? I think you got taken to the cleaners, unless you specifically told them you want a maximum economy tune. Look at your AFR at bottom of chart printout. As Smokey said- "lean as hell". No wonder your pipes blued. is that 16.16 AFR the "after tuned" run?? the HP/TQ lines are fairly jaggy as well.
Lots of shops with a dyno but unfortunately very few are actually good dyno tuners.
I never expected to see over 14.1. I had to pull teeth to get the afr chart. Not happy at all. They are blaming using tail pipe sniffer as why so lean. A good operator would have errored on rich side IMO. They better get better schooling as the guy just got back from a week of dyno school. Must have skipped afr day.
yeh they plain don't know what the F they are doing.
A good experienced tuner makes a good dyno operator and tuner.
A dyno machine and some internet or vendor-provided classes does not. That's just ludicrous. It takes years just to become decent and a whole lot of years to become very good.
Hell they should have paid *you* for providing a bike for their "OJT" learning experience. Get your money back or call your CC company and charge it back.
And they should ALWAYS give you the dyno chart before and after. That is YOUR property that you paid for. If they can't give you printed verified evidence of all results then it never happened.
One more thing to consider- HD Dealers are not allowed to do anything outside the EPA guidelines. Period. So any tune you get from an HD dealer, on a dyno or with a loaded HD stage1 tune map, is going to remain within EPA guidelines (lean). They have no choice in the matter, it's corporate mandate.
Buy your bike and do warranty service at your dealer.
Go to an independent specialist for anything relating to performance and performance tuning. End of story.
I don't think all follow that. My last bike was tuned from different dealer further away and with cams it ran well and hugged below 14.0 the whole way. Once they replace my muffler and collector heat shield I'll be going elsewhere if they screw it up again. I'll let them redo it with current muffler before new arrives and demand no higher than 14 across the board. That lean is robbing power and also may hurt my motor.Last Indy near me didn't seem to interested in doing it. Going 3-4 hours one way without more motor work for dyno seems ludacris but I guess that's the way it goes.
well sorry you are sort of stuck with them- but there is a lot more than just asking for a minimum 14- your AFR table and VEs hit a wide range of AFRs depending on load, throttle position and rpm. idle, low load, cruise areas will be leaner like 14.1-14.4 on the economy end of things. throttle roll ons and WOT would see ranges of 13.8 to 13.1 to 12.8 and even 12.5.
the other end of things is tuning the spark advance tables to optimize power / tq. and all of that takes experience. I do hope they do a decent job next time around.
slydog- was going to say, if there is a dealer operating outside of company policy they will get smacked down eventually. Glendale Harley in Los Angeles was "the place" to get any performance work done and serious dyno tuning. it was actually one of the best places to go in LA for performance tuning, period. they had to close up shop end of 2014 due to new corp policy, sold the dyno machine, and can't do any work that is not within EPA guidelines or CARB compliant. Not even installing a Stage4 SE race kit. I had a long chat with the service manager about it.
I'm pretty sure you got your question answered over on HTT.
Mostly yes. The biggest factor I am dealing with is the blame on the tailpipe sniffer being requested as opposed to drilling the headpipes. They never stated I would get a crap tune from that but also are trying to blame that for the lean afr. Hoping stroker or Joe would answer that question. I see it as a blame for lack of ability to do a proper tune but I am not a dyno operator.
that's pretty funny- blaming an inanimate piece of equipment for operator inexperience or failure. I would question whether the probe was even calibrated correctly, and ideally they are using a two probe machine and not a single probe.
this page too- excellent read from top to bottom especially as it pertains to stock AFR ratios for 2006-earlier bikes (ideal) vs 2007-up (EPA mandated lean) bikes. http://www.nightrider.com/biketech/Pro_tuning.htm
Joe just answered your question but I'll say the same thing. Bring it back, get them to replace the pipe and get someone else that actually knows what they're doing to tune your bike.
