Power Vision Information Thread
Would it help if I smoothed that cell in the rear VE table?
Not sure if this will help but I had an issue last fall, the motor wouldn't idle worth a damn. It would idle then drop off and the (compensator) would start clanging. Took it to the dealership, the head mechanic whom I know after two week gave up in frustration. He replaced a few sensiors, check many things out, etc... I even got Pat Daniels from DJ involved, still nothing. I brought it home checked everything I could, I also have a '07 Deuce (2000 miles) so I swapped out every sensor, plug wires, coil everything I could think of even the ECM (loaded with the 120 tune), nothing. I then used a product recommended for cleaning and increasing electrical contacts, I did every sensor and even the ECM plug. Then I bought the TT, plugged it in and no more low idle issues. So to this day I have no idea what the problem was, been advised just to be happy and forget about it but it's still in the back of my mind.
Smoothing manually is nice for the eye, but the engine wants what it wants. If you manually change ve numbers without making any changes to the cde or physical changes the ECM will eventually work back to the original number. It just the way it is.
I looked at the original dyno tune from a few years back and noticed a difference in the front cde, it was lower, don't know how it would change. The rear was a tad lower but higher than the front. Could I copy and paste that to the current tune? Also, somewhere along the line the AFR changed outside of the cruising area (above, below and to the right) from the original 13.6 to 14.0, not by me. I did have AT before TT/AT.
As always thanks. Dennis
Thinking, if the PV spark learning feature can trim excessive spark from learned cells, then we should be able to bump areas of the spark tables higher than needed, run a spark tuning session, and let TT-AT trim as needed. where it is trimmed should be just before points of detonation and (hopefully) close to MBT. of course keeping a safe max retard value of 10 so as to not cause any actual harm in the process.
otherwise I'm not sure what the intention of the PV's spark learning feature actually is? The ecm itself already has a learning process but that is more for safety reasons than performance optimization.
I'm on my third bike with a PV and it's been plug and play on all three. Do I have a tune comparable to a 4 hour dyno session? nope, but I'm not drag racing and based on several years of riding trouble and heat free, without any hiccups and on all three bikes, it's been installation, at the maximum 4 AT sessions and then just ride, ride, ride. I'm pretty confident (Jamie might want to comment here, as I know at least part of his income comes from hours on a dyno) that the 5% I might pick up is really down there in the law of diminishing returns..
Note that I really don't want to discourage the current discussions, as I'm benefiting from them every day (first thread I check every day, just to see what Dog is up to), just hate to think somebody might be scared off....
You nailed it- it is probably the best complete plug-n-play system for accurate fuel tuning, the PV plus the TT add on. get TT-enabled map, do a few TT-AT runs, done.
I've mentioned a few times that we need an "advanced PV tuning information thread" so we stop polluting this one with deep specific discussion, but right now this is really the only central source for any and all discussion. but it should not deter anyone looking at getting the PV for getting a better running bike and it's overall pretty easy to use- provided that you buy it from FM directly, since they provide much better 1st time user instruction and follow up support.
for the advanced tuning use, there is merit to optimizing things like spark advance / fuel curves for best performance. I see a large difference seat of pants with a tweaked timing map vs stock timing map, mainly in the off-idle and roll-on areas. the stock timing maps are somewhat detuned. also I can lower my ET's at idle and slow cruise in hot weather by not running such excessive stock advance in those areas and richening up the fuel. but most riders will never care about this and it's not a requirement to make changes to those areas.
From an advanced tuning standpoint, I find the PV system severely lacking in utility and guidance to someone who does not know anything about delphi or tuning. the manual is horrible beyond anything basic, there are no comprehensive tuning guides, there are no log data utilities for assisting with optimizing all areas of the tune based on captured ride data. Yet the mfr is one of the best sources for dyno tuning equipment with literally millions of hours of logged dyno operations.
I hate to say it but I found that one of my best sources of data are the TTS manual and tuning guides. And I look at some of the tuning aids they have with their Datamaster log analysis software, as well as the automotive delphi tuning products and their log analysis capabilities, and it really has me wondering why DJ has dropped the ball on this- We have all the good raw data in the PV logs, but no way to intelligently process it into advanced tune optimizations without requiring years of understanding tuning / reading logs, and using other data analysis products with steep learning curves like MLV- or - hoping a knowledgeable forum member will help out.
This post is not meant as a complaint, rather an observation- overall I'm happy with the PV and glad I bought it, it is a quality product. Just not pleased that such a powerful tuning product is cut in half by not including intelligent log data analysis tools, decent guides, and suggested peak power configurations based on DJ's years of collected dyno run data and dyno tuning experience. Hopefully DJ will put some more thought and work into the advanced user side of things, which would make an excellent product even better for those 5%'ers like me.
In the interim we're lucky to have members here with advanced tuning skills willing to help out with the advanced questions, provide custom tunes, etc.
