Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Andy- I can only give a very basic summary of what Jamie changed - I'm sure he can elaborate further. Roy at DJ used a timing delay method to keep injectors on for decel. Jamie changed that back and instead used a MAP-threshold method of keeping injectors on for decel. He also added a bit to my VE tables. The method Jamie used was immediate in positive effect - logs are attached with complete signals, riding in normal mode no auto tune enabled.
I have to honestly say I have no idea why the changes worked but they did- I am looking at the logs and the same decel events show 17.9 AFR, same as before. and my decel VE's are lower than before, my AFR's in that area are leaner than before. my decel timing is the exact same as before.
my logs show the requested 12.9 AFR for the decel event map, rpm and 0TP - but WBO2 F/R report 17.9 AFR (meaning injectors did shut off, correct?)- and no cherry bombs. Mr. Wizard did some magic that I clearly do not understand
You have to ask yourself what decel pop is. It is raw fuel being ignited in the exhaust because the exhaust temp is higher than the flashpoint of the raw fuel. By adding fuel to the decel area you lower the exhaust temp below the flashpoint of the fuel. I've been using this method for well over a decade. It works.
Yes I completely agree and that is typically the method I approach this issue with- Adding fuel and in some cases advancing decel timing. Nothing I did along those lines helped on the very narrow rpm backfire issue at hotter ET's, and the issue itself only presented after moving to the Target Tune and wide band operation. Decel overall was fine- just that single anomalous event was way out of hand and not responsive to typical fixes. But in this case Jamie seems to have removed excess fuel, or some other behind the scenes change with the injector operation that resolved it. my VE's and AFR are actually set much leaner than before.
Most of what he did was turn off the injectors in over run. No fuel, nothing to burn in the exhaust.
We can hand tune the fuel in a little closer if you want.
You do have some knock on the rear that we may want to deal with.
Andy
Thanks Andy- I've seen the knock but not overly convinced yet of validity. I can do another run back to back and I won't see anything higher than 2's, same rpm / map load / ETs. I have one log here that shows 0.5 degrees of rear knock with the key turned on but engine not started! Anyway I'll keep an eye on it and trim areas as needed.
What did you mean by tuning the fuel in closer - reported AFR's vs set lambda?
Gotcha. Weird it only showed up after running the tt MAP.
A little racer trick regarding chasing down detonation/noise. Get tank of better (about 5 points higher) gas than you are running now. If the detonation in the logs gets better, you are chasing real detonation. If there is no change in recorded detonation, most likely you are chasing some other issue.
I have read and read and read some more on this thread and the info is endless. But what i cannot find is regarding tuning my timing. I Dont have many if any knock events so I wanted to push my timing until I started to get minor knock events and back it off a hair. The best way I can find to do this is through log tuner, There is just one problem. I cant find a download for the log tuner anywhere. Did DJ stop the log tuner download when the autotune basic launched or am I missing something. Just looking for the log tuner software to load my data logs into to help me make heads or tails of my logs.
