Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Gozzie, do you have a data log off the bike running around on the street? Just a typical ride.....
I don't have any logs saved as of now, but I can log some next time I go out. It might be a couple of days. I would love for you to look at them for me. Would standard auto tune runs work or do you need any specific channels ?
I am new to the PV tuning thing but have done a few auto tunes so far .My question is I have Andrews cams installed and was wondering if anyone has already done a tune for these .I have catless pipe and a k/n filter .
Bike runs good but I do hear a light ticking at idle when in hot weather .I don't really have the right experience to mess with timing on my own the first time out the gate.
Just wondering if I can get a base tune for Andrews cams to start out with .
More info please:
what year and model HD?
which Andrews cams??
Thay "clicking" sounds like the throttle body. It is called reversion and is normal. Be care with the amount of timing change you do.
Just did my first AT Basic. VEs adjusted -6% to -15% on first go-round. Here's my question- working in 90* temps; is that OK? Or should I be working at lower temps? Thanks
I've got a strange problem with my PV in that the acceleration enrichment and deceleration enleanment signals don't show any data, either if I add the signals to the data log list, or display them in a gauge.
What I get is a blank all the way down the data log column, no 0's with occasional numbers that I see in other peoples logs.
I take it these two signals should be there in a 2014 softail (358 map)?? any ideas??
cheers
Any chance you are still running an autotune map (autotune enabled)? That would disable the enrichment/enleanment functions.
