Power Vision Information Thread
Old Oct 14, 2018 | 10:11 AM
  #9121
brianfl67's Avatar
brianfl67
I had a power vision on my last bike before they added target tune. I have a 2017 street glide cvo all I'm changing is the pipes do I need the target tune? Thank you
Old Oct 28, 2018 | 09:12 PM
  #9122
oldhippie's Avatar
oldhippie
No, all you need is the Powervision. You might want to consider also getting the header pipe as well. I'd strongly suggest Fuel Moto for the purchase. The price will be right, the support is the best, and I believe the double the factory warranty. Seriously Fuel Moto for the PV, the mufflers, and the head pipe should you go that way.
Old Nov 4, 2018 | 11:49 AM
  #9123
brianfl67's Avatar
brianfl67
Thank you very much. I am putting a head pipe on and mufflers. Just wasn't sure if I needed the target tune
Old Nov 16, 2018 | 10:31 AM
  #9124
antlockyer's Avatar
antlockyer
Had to do some work to my motor to fix worn out parts, ended up changing the cams while I was there. I've gone for my target cams even though I know the compression ratio isn't there to support them yet. Once more money comes in I can change the pistons and port the heads.
In the meantime I'm trying to get somewhere near a sensible tune. Did a few autotunes and the bike runs pretty good. Looking at the AFF % though the front cylinder is way leaner than the rear.
Should I be globally adjusting the front cylinder down closer to the rear? If there is more info in this thread about this situation, please tell me and I'll go and search for it, I couldn't find it when I had a longish look.
Old Nov 16, 2018 | 10:46 AM
  #9125
antlockyer's Avatar
antlockyer
I've just notice that instead of 4.35 Injector size (2015 FXDB) I've got 3.91. I guess change that and autotune again from there?
Old Nov 16, 2018 | 11:39 AM
  #9126
slvrscoobie's Avatar
slvrscoobie
Depending on how interested you are, you can open the tunes in the dynojet winpv and adjust the fuel (target AFR or VE) individually (front vs rear). Maybe make some global adjustments on the cylinders, as if you 'globally' do it in auto tune, itll run rich on the rear and normal on the front otherwise.
Old Nov 16, 2018 | 11:49 AM
  #9127
antlockyer's Avatar
antlockyer
I'm extremely interested. I would absolutely love to get a handle on how to tune my bike by analysising logs etc. I've just bought Megaloviewr HD to play with too.
Old Nov 16, 2018 | 12:04 PM
  #9128
antlockyer's Avatar
antlockyer
Just quickly playing in Mega log viewer I searched for the highest front AFF.
At that point this is what I saw
Front AFF = 110.2
Rear AFF = 96.1
RPM = 2507
TPS = 48
MAP = 102.55
Fonr VE = 103.5
Rear VE = 110.0
So my limited understanding so far tells me that the VE table is adding more fuel at this particular cell on the rear cylinder compared to the front.
Looking in WinPV shows
Looking at the cells in the tables would back that up. Correct?
Old Nov 16, 2018 | 12:15 PM
  #9129
antlockyer's Avatar
antlockyer
and just because I'm having so much fun I've doe a histogram of the delta of Front and Rear AFF
It seems to be concentrated in the 2000-3000 rpm range and worse at high throttle openings.
Old Nov 19, 2018 | 11:18 AM
  #9130
antlockyer's Avatar
antlockyer
Looking at the above I think I'm way off base so all I want to do right now is get a decent base map to start autotune from. I got one from the cam supplier but I get this
The tune was for a 2012 bagger, mine is a 2015 Dyna. I did an update tune using PV but still no dice. The Software Level on this tune is 202 my other tune is 357.
