Power Vision Information Thread
Old Feb 24, 2018 | 11:42 AM
  #9021
david barnby's Avatar
david barnby
Will check it out- assuming that your thoughts are “check before smoothing or leaving as is”?
In my search I see the ECM actually compares a requested VE to those around it and will ignore a material change. But I believe that is for newer ECM versions than the 2001 I am tuning. Learn a lot comparing what is available from (and what can be done with) the ECM comparing my 2010 and 2001 WinPV charts and menus.
Cheers again
Old Feb 24, 2018 | 11:59 AM
  #9022
shanneba's Avatar
shanneba
If you want to try smoothing, save a copy of your tune, try the smoothing in the new copy and flash it.
The smoothing seems to be a little on the aggressive side to me. (no expert)
Looking through VEs in my logs, it looks like the ECU will use values between two adjacent cells when the other parameters are in between. Say you are running 3250 rpms, it will use the 3000 and 3500 VE values to estimate the value at 3250. (it seems to do the same with ignition timing)
If you running a closed loop / adaptive control tune, the CLI / AFF will also be used in calculating the fuel injection duration in closed loop portions of the tune.
I have only looked at data for a 2007-2013 Sportster, I have seen the newer tunes for the Sportster have added additional capabilities such as knock control and "Lambda range" to widen the closed loop control capability with the heated O2 sensors starting in 2014.
Old Mar 29, 2018 | 07:01 PM
  #9023
OLD 96's Avatar
OLD 96
Default Lack of Guidance with PV.
Does any one know of ,or, has made a complete set of instructions for all of the different features on the Power Vision? I just received my Power Vision. All it comes with is a very minimal set of instructions. It does not even begin to scratch the surface on all the functions this unit can do. I have been watching You Tube videos. But. It would be nice to have a "manual" for this unit. Thanks. OLD 96.
Old Mar 30, 2018 | 02:51 AM
  #9024
david barnby
Know what you mean. Is a hard one though because if you want to not fly blind it is not the tuner that needs understanding but the bikes Fueling and ignition system. With a grip on that you can then demand the PV to do certain things and it will. Read one (or two) of Greg Banish’s books. I have two, one written in the last decade and one this. Seeing how the books covering the same topics but with the technology available when written helped my understand so much and the light bulb in the head switched on regarding the PV and other tuners.
The tuner maker would have to take you on the same journey as these books to expalain their tools for working with eg MAP / VE / WOT etc
HOWEVER - that’s for tuning instructions. Regarding all the other stuff you can do with a PV I too would love a guide on setting up gauges etc. I see riders showing their cylinder head temps etc and think ooh must try that but......
Old Mar 30, 2018 | 04:19 AM
  #9025
shanneba's Avatar
shanneba
Here are some helpful resources:
Fuel Moto has a list of PV info: Choose the "Downloads" tab (under the Buy Now box)
https://www.fuelmotousa.com/p-28398-...M%20XL%201200C
Harley has online training for the SE tuners that include some EFI info along with helpful tuning instructions: (it is geared to thier software/hardware)
Super Tuner- http://prosupertuner.harley-davidson...ENU/index.html
Street Tuner- http://streetperformancetuner.harley...ENU/index.html
Dyno Jet has a number of resources for the PV:
http://www.dynojet.com/powervision/p...Power%20Vision
Power Vision User Guide for the Power Vision WinPV Software
http://www.powercommander.com/downlo...8100016.08.pdf
Here is a link to DynoJet videos:
http://www.dynojet.com/powervision/p...on-videos.aspx
"How to set up Power Vision Gauge Display"
Old Mar 30, 2018 | 04:37 AM
  #9026
DonnieM's Avatar
DonnieM
The links provided by Shanneba are a good source of info. I actually read this whole 900+ page thread before I bought my PV and AT kit. Long reading through the posts, but it provided me a better understanding on EFI, and how PV works. I had to buy the V&H Dresser Dual headers to use the AT on my '06 Ultra. The end result, my Ultra runs better than it ever has. The shop that fixed a Tranny leak a few mo back for me does Dyno. He asked me what I had done to the bike. His seat of the pants road test must have went well
Old Mar 30, 2018 | 09:33 AM
  #9027
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Those are good informational links for sure. You can also refer to the Power Vision section on the Fuel Moto University knowlege database here:
https://university.fuelmotousa.com/h...t-Power-Vision
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Apr 1, 2018 | 05:37 PM
  #9028
dwl25's Avatar
dwl25
I have a Power Vision that I got from Fuel Moto. I have been reading as much as possible and pushing various buttons on the unit.
My question is when I went to Quick Tune and clicked through to the screen with the EITMS and Knock Sensor etc. The EITMS selection was greyed out and there was no check mark. I tried to check it but couldn't. I rolled the throttle and the engine light turned colors. That says to me that it is working, right?
I checked the knock sensor and it went on and off as I expected.
Am I supposed to be able to check the EITMS.?
I have read there is a place that the temperature the EITMS comes on and off at can be adjusted. Where might I find that?
I know I could call Fuel Moto tomorrow but I figured this was just a beginners question that might be better placed here.
Thanks
Old Apr 1, 2018 | 07:09 PM
  #9029
shanneba's Avatar
shanneba
What year and model bike do you have?
Does it support EITMS?
If you have a computer with WinPV installed you can download your tune from the PowerVision and look at the settings.
The EITMS temp are in the Environment Folder.
The Enable / Disable EITMS is under Limits and Switches.
Old Apr 2, 2018 | 05:23 AM
  #9030
dwl25's Avatar
dwl25
Sorry, I have a 2014 Road King and it has EITMS. I found the section in WinTV that enables the EITMS and it is set to 0 and the temp is set to 305. I have flashed my bike with that tune. Since WinPV was set to 0 will that still allow the bike to activate EITMS?
I guess the same question is for ACRs as well.
Thanks
