Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
You need the target tune not autotune module, the TT connects also to the OEM sensor inputs. Using the autotune I believe you need to load a tune to the ECM that tells it not to look for the stock sensors. Suggest an email to Dynojet if no better answer here.
Use the diagnostics on the PV to pull up the DTCs. It will probably show a code for both sensors. Just clear the codes. That will probably solve your problem.
if nothing plugged into the sensor inputs that wont help unfortunately
It sounds like you are using the AutoTune Pro unit with the PV.
Why did you remove the narrow band sensors?
You have the bungs for both, so use them.
Put your narrow band sensors back in, clear the codes and go from there.
