Power Vision Information Thread
I've got a Canadian bike but when I want to read speed on the power vision it defaults to miles. Buddy of mine bought a PV not long ago and his reads km so I assume it's possible?
I might have had the WinPV open at first. Now it is closed and the Update Client is still not recognizing the PV2. I have a pop-up that states:
"Please connect your Power Vision to your PC with the provided USB cable to check for necessary firmware updates."
I click OK and another pop-up says:
"No Power Vision connected. Please check any PV's with a batch number below 110201 for a CRITICAL SYSTEM UPGRADE."
Is it possible that WinPV is still running in the background?
. Vehicle Speed Sensor (VSS) is used to calibrate the speedometer. i.e. Number of Pulses per KM. (actually pulses per 1/25 km (if you believe the documentation) but who's counting). VSS is not used to change the display from MPH to KPH.Settings Menu
To Select the "Units"
- Select Settings > Units
- Select English or Metric
I have a power vision to use on my 2010 fxdf, which has rinehart crossback pipes and a S.E. air cleaner. When I bought the bike a month ago, with 11,000Km showing, it had not been tuned for those modifications. pop pop pop and the odd backfire. It had original plugs in it and they showed running lean of course.
I paid fuel moto for a tune license for the power vision. They also supplied a tune for my bike. Dynojet also has a tune on their website for a 2010 dyna with those pipes and filter.
I changed the plugs and tried both of those tunes. The tune from the dynojet site works better, less popping on decel. I actually still had the odd backfire when using the fuel moto tune.
To fix the decel pop I added fuel and spark under quick tune following the instructional video. I went to +8% fuel and +5% spark in decel. It helps but not completely. If I ride the bike hard and then try to cruise back into my hood somewhat quietly like a law abiding citizen, it's pop pop pop....like jiffy pop anytime I'm off the gas. So it's poppy when hot.
I tried auto tune and didn't make out very well. I thought I followed the instructions and got it into that mode.... engine sounded unhappy, barely started, backfiring. I rode it for a bit like that and the cells were populating. I saved the session, didn't export it. It can't be normal for it to run like garbage in auto tune is it? Did I miss a step?
Should I just add more fuel/spark in quick tune and be happy with what I've got?
Plugs are looking ok after 1000Km... picture attached. A little cleaner than I expected but at least not white.
a good starting point for now
when you riding set the gauges on the PV to show you AFR, HT, REVS and MAP - Watch what is going on. If you are at 4500 revs and hit a grade you will see MAP increase, if the bike doesnt power through richten the AFR for those sells. If you are cruising at those REVs the MAP will be lower, if it runs easy lean up the AFRs in those cells for fuel economy
good thing is you can ride and tune at same time and you learn a lot in the process....
have fun and good luck
REPORTING BACK! Just to update on the comments from david barnby, you were spot on! I have been out on a few rides now and the changes are perfect. I was way too lean. Last ride I only have 2 front knock events in a 3 hour tour! I know they were from throttle blip, so too quickly opening the throttle is the culprit. Bike runs like a scared rabbit! Thanks.
