Power Vision Information Thread
Old Jun 3, 2022 | 12:32 PM
  #9481
Richard Bruce's Avatar
Richard Bruce
Originally Posted by lightweight bob
Richard Bruce,
Do yourself a big favor and rent a trailer. Doing 100 miles on a bad tune can waste that top end - don't chance it.
Just my honest opinion.
Kinda what I was thinking. just wanted some honest opinions. I appreciate the response.
Old Jun 5, 2022 | 05:29 PM
  #9482
Richard Bruce
Default TT question
Is it normal for Target Tune to hunt around so much at idle for AFR. I idle at 30-34 KPA. During heat Cycles I noticed the front Cylinder WB02 is 13-17AFR while back stays near targeted 13.8-14.3. TwinCam D&D boarzilla exhaust. Star Racing 650 cams
Old Jun 5, 2022 | 05:47 PM
  #9483
Richard Bruce
Also, does Target Tune on a base map with Target Tune enabled supply fuel based on the VE table, or does it supply fuel based off the fuel map for cylinders? Would my base map be so far out that the VE's would make it hunt around that much while idling because of the massive amounts of upgrades I've done. DJ supplied a map that in the description was basically my setup or Dyna I have a softail FLSTFBS but boarzilla 650 cams. I doubt they had the heads done up like I did but would that cause this behavior OR do I have something else going on? Would a intake leak, exhaust leak cause this behavior? Just doesn't seem normal. I'm taking it to a dyno tuner but I want it to be good to go for him.
Old Jun 6, 2022 | 06:07 AM
  #9484
jjdaly's Avatar
jjdaly
cams make a huge difference in breathing and injection timing and egr/cde, and....... you get the idea. but yea, even with TT the ECM still does the same thing as it always does, it's just tricked into using WBO2 instead of narrowbands.
Old Jun 6, 2022 | 09:01 AM
  #9485
Richard Bruce
This is my log from a heat cycle.. does the WB Front look normal and could be attributed with the tune rather then something else? I appreciate your time. I initially thought it was an intake leak but I've done the intake seals 3 times and now not so sure..
File Type: csv
Old Jun 6, 2022 | 11:01 PM
  #9486
Richard Bruce
it really doesn't matter. Joe Lyons is the man and can get her going. Thanks for the information
Old Jul 4, 2022 | 09:02 PM
  #9487
Richard Bruce
Default 15-17.8 AFR at decel while cruising
I got my bike back and put about 300 miles on it. I currently have TT/WB hooked up to it. I noticed Hella decel popping and while doing cruising anytime I let off the throttle it jumps to 17 AFR. This is anywhere from 10-25KPA and 1000-4500 RPM. The TPS is at 2-3% enclosed is my log. This is professionally dyno tuned. Any suggestions? Can this hurt my motor? Should I add fuel, spark, or both? Thanks.
File Type: csv
Old Jul 5, 2022 | 08:03 AM
  #9488
2deuceguy's Avatar
2deuceguy
Contact who did the tune and let them know. If they're remotely reputable they'll get it in asap and make the needed corrections.
Old Jul 8, 2022 | 11:52 AM
  #9489
yo_marc's Avatar
yo_marc
1st Gear
Something I would like to understand better:
If I run a factory-like closed loop map with adaptive control enabled (which learns and applies correction factors over the set VE table), why is it that we still need to tune our VE tables when we modify the bike? (lets just say Stage 1 mods)
Is it simply because there are areas of the map that are open loop and will never learn through adaptive control? Or is it that adaptive control is in some way inadequate?
Old Jul 12, 2022 | 09:58 PM
  #9490
jjdaly's Avatar
jjdaly
it won't hurt the motor. 15-17 AFR on decel isn't abnormal, you've shut the throttle and have high vacuum telling the ECM you aren't under load in the least and it's not putting much/any fuel in. and if decel fuel cut is active it's definitely not putting any in. if you're getting those AFRs when you are on the throttle and MAP values above 50-60, then yes that's when you should be complaining to your tuner. decel popping won't hurt either. that's one that can be difficult to impossible to tune out completely depending on your exhaust type.
