Power Vision Information Thread
Old Oct 23, 2023 | 07:51 PM
  #9581
smitty901's Avatar
smitty901
Forget 3and 4 go with the real deal with no phone involved.
Old Oct 24, 2023 | 12:05 PM
  #9582
LRS's Avatar
LRS
Originally Posted by yamahog
I would go with the 2 or 3. The 4 is only if you plan on tuning it yourself.
Dyno shops don't use the 4 yet and might not use the 4 ever.
I don't understand why though.
I wonder why? Fuelmoto says the pv4 can be dyno tuned.
I really have no gripes with the way my 2015 103HO performs. It gets good fuel mileage & Im not racing. I have no plan to do anything other than stage 1 unless something breaks. Only reason Im looking into tuner is the heat at cat. Im considering decatting. Already have v&h 4.5” slip ons on it and a stage one ac sitting on the work bench. I know if I decatt, and add the open air filter It will be super lean.
Old Oct 24, 2023 | 12:24 PM
  #9583
yamahog's Avatar
yamahog
I know it can be dyno tuned, but the method is different in how it's done. The pv4 is more of an access doggle for the software to use that being a stand alone unit.
The best way to to loose the cat is with a new headpipe, better flow all the way around. There are headpipes that you can still use your existing slip-ons with that will flow better than your stock pipes with the cat punched out
Old Oct 24, 2023 | 09:25 PM
  #9584
Rollbar's Avatar
Rollbar
Agreed, but the stock intake can only bring in so much air if I'm not mistaken so it's a total volume thing on both sides of the air pump.
I'm thinking of doing the catalytic converter removal as well.
PO=no baffles but I did add the DK Thunder Torque inserts so that might help, not sure.
Old Oct 24, 2023 | 10:30 PM
  #9585
yamahog's Avatar
yamahog
I have 2019 with a SE stage 4 kit that has the 64mm throttle body and intake manifold, CNC Ported heads, SE 515 cam, Rinehart 4.5 slip-on mufflers and super suckered air folter system. My restriction in the stock headpipe. I just don't have the money now. I have a powervision pv1/2 that I was able to transfer from my 2011 that was totaled out from a hit-n-run
Old Oct 26, 2023 | 05:01 AM
  #9586
brownie4412's Avatar
brownie4412
Just went through this. The shop I went to pulled the license from my PV4 and used their shop PV to tune my bike. Apparently that's easier than just using the powercore software that the PV4 uses.
They did say that they didn't know how plugging the PV4 back in and pulling the new tune with it would turn out, so they didn't plug it back in when they were done. They did send me the tune file, so I think some day this week I'll try and plug the PV4 in and see what happens. I do like the available gauge layouts in the ap. I'd hate to lose literally the only useable feature of the PV4.... we'll see.
Old Nov 6, 2023 | 11:07 AM
  #9587
yamahog's Avatar
yamahog
At this point the PV4 will be a monitoring tool
Old Nov 6, 2023 | 06:07 PM
  #9588
brownie4412
Exactly this.
Old Nov 11, 2023 | 08:47 PM
  #9589
2deuceguy's Avatar
2deuceguy
All you need to do is open powercore and convert the pvt file (map they made for you) to a djt file and save that to your cloud. When I tune w/ a PV4, I transfer the license to my PVOG and tune w/ that, then transfer the final map to the djt file and use the PV4 to flash into the bike, that way the owner will have that file in their cloud should they need it for whatever reason.
Old Dec 19, 2023 | 06:12 AM
  #9590
Rounders's Avatar
Rounders
Is it your first harley or first newer harley? I am really happy with the same bike. I bought it used, so I don't know if if decatted, I forgot to look when pipe was off. He said stock. It is stock pipe and pretty much everything else.
My 2007, first year of 96 and epa changes, that is hot. Myself and OL don't notice it on this bike.
