Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I was having similar issues with it freezing except mine would actually write a new tune file with the values changed. The latest firmware update seemed to work better but still froze on the 3rd autotune I ran. Have you updated the firmware on your PV3?
it says up-to-date no new firmware available
It writes a new file, but when I compare them, theres absolutely zero changes
I'm sure this has been answered in the 957 pages of this thread however, I just installed the Target Tune with my Power Vision on my 18 FLHTK. I have the gauges set to show AFR1 and AFR 2. I am assuming that it is showing by the front and rear cylinder correct? On a side note, if this unbearable heat would subside in Texas, maybe I could get out and ride
To view live AFR with Target Tune you want the channels WBO2 AFR front & rear from the vehicle signal list, AFR 1 and 2 are for use with Dynojet dual channel wideband controller on the dyno or with AT Pro. There is a helpful FAQ on our website on Target Tune here>> https://university.fuelmotousa.com/a...rget-tune-faq/
So using the image shown, these are the correct ones I need? Also, do I need a new tune map made specific for the target tune addition or do I only need to convert it and flash to the bike? Thanks
Front and rear VE tables are different because they each have their own requirements: Separate injectors, inherent small mechanical differences in airflow, and compression. Also, there is some "spit swap" occurring within the shared intake manifold/TB, caused by the odd firing sequence (315°/405°). They also have separate timing tables and separate coils, & different spark timing requirements, due to cylinder temp.
