Power Vision Information Thread
Old Aug 23, 2023 | 10:17 AM
  #9571
07UltraGuy's Avatar
07UltraGuy
Originally Posted by SSG_B
Then when you are running in full closed loop, is the tuner adjusting each cylinder seperatly?
Hence the reason for two O2 sensors…
Old Aug 23, 2023 | 10:57 AM
  #9572
SSG_B's Avatar
SSG_B
Sorry for what may seem as ridicules questions as I used HP Tuners for a few years on Corvettes ,and although the computer showed different VE tables per gear, we just matched them to be the same. No tuning of each cylinder. Hence my question about the different tables for the bike. Thanks for all the replies. Hopefully I can get some riding in soon and see some gains.
Old Aug 23, 2023 | 10:08 PM
  #9573
CSt6804's Avatar
CSt6804
You are basically tuning two separate engines connected at the crank and intake. Thats how I view anyways. The factory tunes will also have different timing and VE tables for the front and rear cylinders. There are no MAP based tables. TPS only. I believe they are there. Just not available to the hobbyist types but im not 100 percent sure about that. Maybe a pro tuner could chime in on that.
Old Aug 24, 2023 | 07:53 AM
  #9574
rigidthumper's Avatar
rigidthumper
Map based VE tables do exist, on specific models, like the 2010-2013 Touring platform.
Old Sep 20, 2023 | 04:42 AM
  #9575
brownie4412's Avatar
brownie4412
Originally Posted by fuelmoto
To view live AFR with Target Tune you want the channels WBO2 AFR front & rear from the vehicle signal list, AFR 1 and 2 are for use with Dynojet dual channel wideband controller on the dyno or with AT Pro. There is a helpful FAQ on our website on Target Tune here>> https://university.fuelmotousa.com/a...rget-tune-faq/
Jamie,
Any idea when they are going to roll out the "features" for PV4? Auto-Tune, Live-Cell data, ect....
Old Sep 20, 2023 | 11:13 PM
  #9576
Rollbar's Avatar
Rollbar
Originally Posted by brownie4412
Jamie,
Agreed, that would be awesome!
Old Sep 21, 2023 | 04:17 AM
  #9577
brownie4412
I can't even find someone near me that has used the new powercore software to tune a bike. Maybe I'm not talking to the right guys but they've all acted pretty hesitant about using it.
Old Oct 10, 2023 | 03:45 AM
  #9578
b1gb2010's Avatar
b1gb2010
I see there was a new software update for PV3 couple days ago does anyone know what they updated or have update notes?
Old Oct 23, 2023 | 05:50 PM
  #9579
LRS's Avatar
LRS
Originally Posted by Pender1
Hey guys, I'm shopping for a tuner for my '16 Ultra Limited and it's come down to the PV3 or PV4. Being that we're 1 year+ after the release of the PV4 and it seems like features are still limited on it, is the 4 worth buying at this point or am I better off grabbing a 3? Going stage 1 for now, cams will probably follow in the next couple of years. I'm buying from Fuel Moto either way, so I'm expecting good support for either unit based on their reputation.
I have a 2015 ultra. What route did you end up using. I plan to get a tuner, decat stock head pipe. I have a new Arlen Ness super sucker and vance & hines 4.5 titan slip ons. I dont plan to do anything else but ride it.
Old Oct 23, 2023 | 07:25 PM
  #9580
yamahog's Avatar
yamahog
I would go with the 2 or 3. The 4 is only if you plan on tuning it yourself.
Dyno shops don't use the 4 yet and might not use the 4 ever.
I don't understand why though.
