Power Vision Information Thread
Old May 8, 2016 | 08:41 PM
  #8481
LA_Dog's Avatar
LA_Dog
^^ Roger that, appreciate the advice brother. going to run this next one with 110CI tomorrow, rain rolled in and cut my fun short.
Old May 9, 2016 | 07:45 AM
  #8482
adkg12's Avatar
adkg12
I was reading about CDE, and the effect it has on your VE tables. Whenever you have a group of cells that are you hitting that 127 cap, to lower your CDE a little at a time in that particular range, and it should fix that VE issue. But I havent done that yet. I did do a number of AT runs this weekend at all different types of riding, and there are a few things I notice right away. First, I limited the AT to 30KPA and up, but for whatever reason, the nice idle sound (lobing sound) that I had before is gone. So I will be working on trying to get that back. However, my fuel eco improved quite a bit just by AT'ing the rest of the map! Just using the instant eco, it has improved about 10-12mpg! I can feel the engine a bit smoother on the highway. And although I can feel a slight loss in that SOP power at bottom-to-middle power, it still pulls much better than stock. I have NO ping, and overall it runs great. I am wondering if I could pull just a bit more out of it, by moving the timing...? I can see my map tightening up in MLV, but I dont really know what to change after looking at the MLP plot anyway..LOL!
Thanks
Glen
Old May 9, 2016 | 08:51 AM
  #8483
LA_Dog's Avatar
LA_Dog
Adjusting CDE only has a significant effect below 60kpa. If your 127 VE cell numbers are above 60kpa it's not going to do much. Could be your idle is not longer as lopey because it is no longer running overly rich in the idle area VEs. I can manually richen mine to like 11.5-12 AFR and it gets real lopey. but will equal poor economy. If you want a reasonably priced upgrade to off the line and midrange pull, shorten the belt pulley ratio with a set of 30/68 or 30/70 belt pulleys. the difference SOTP will be very significant without loss of mpg. no amount of tuning will overcome the stock overly tall secondary drive ratio. been down that road
And yes timing can be optimized in the off the line areas, 70kpa-up and 750-2750rpm approximately. then you can further tune the higher rpm / higher map 70kpa-up 2750-up. log data and MLV can help with that. FM's tune maps have that area bumped up a bit, stock maps and HD stage1 maps are overly tame in that area on purpose to help prevent engine damage if the motor is lugged.
Old May 9, 2016 | 08:55 AM
  #8484
adkg12's Avatar
adkg12
Oddly enough, looking at the old VE tables, and the new AT'ed ones, I am actually leaner than I was before...thats why I was confused a little...I will check it out.. as for the pulley idea, I am already looking into it. I have ordered a used one from Ebay and plan to install it this week!!
Thanks
Glen
Old May 9, 2016 | 09:03 AM
  #8485
LA_Dog's Avatar
LA_Dog
Cool- you will be *very* happy with the pulley upgrade. not sure what bike you have.
once you get your VEs dialed in and you see 3% or less of change then you can richen up fuel in the AFR table. for a quick down and dirty test you can set the entire map to 13.1 from 80kpa and down, and 80kpa and up set it to 12.8. that is the "performance" side of AFR ratios. give it a ride, won't hurt anything, see if your power picks up. if it does then you know maybe you are a bit lean in some areas. put your old AFR map back and richen up some areas till it feels better where you ride.
I only set the 30-70kpa and 2500-3500rpm area of my AFR table to 14.0. everything else is 13.2 to 12.8. I prefer more performance and lower engine ET's to economy- but I'm mostly all in-town riding and rarely if ever any freeway. what's cool though is you can build a "town / performance" richer tune and another "freeway / mpg" tune file, switch between them as needed.
Old May 9, 2016 | 01:49 PM
  #8486
adkg12's Avatar
adkg12
Good idea! That might be a good time anyway..LOL.!! I think I will make a tune that way and ride around and log it...Likely not today as the weather is bad here today... So I have to ask, are there ANY good references and documentation for tuning with MLV? Because I cant really find anything.. I am starting to think I got hornswaggled..LOL
Glen
Old May 9, 2016 | 02:04 PM
  #8487
UltraNutZ's Avatar
UltraNutZ
Glen
talk to whittlebeast.. he's the expert on MLV
Old May 9, 2016 | 05:56 PM
  #8488
mirrmu's Avatar
mirrmu
i purchased MLVHD and after some initial problems it works and is great for viewing the logs,
from reading here and HTT it looks like MyTune would be a better software to buy
Old May 9, 2016 | 06:31 PM
  #8489
UltraNutZ's Avatar
UltraNutZ
2 totally different beasts.. I certainly favor My Tune over anything else when tuning for verification of what my VEs are doing and I play with it with timing as well, but I also own MLVHD and it's a beast of an app especially for logging and analyzing those troublesome bikes. My Tune doesn't do much in the way of analytic functions at all.
Old May 9, 2016 | 06:40 PM
  #8490
mirrmu's Avatar
mirrmu
yes MLVHD is great for viewing a log but for most people to then take it to next step and altering the tune i feel is the stumbling block
