Power Vision Information Thread
Old May 4, 2016 | 11:01 AM
  #8471
Scooterbear's Avatar
Scooterbear
If you hit "scale" instead of "cap" your VE's will lower across the board since it adjusts displacement and reduced the VE's not affected by the AT session.
Old May 4, 2016 | 02:50 PM
  #8472
adkg12's Avatar
adkg12
They lower pretty much across the board and I have done ATs and tried scaled and cap. I prefer capped...It rained yesterday, and I think its going to today, so I cant get any logs, but I will as soon as I can. I installed and messed with MLV, and I can see theres room for improvement, but it really doesnt tell you WHAT to change, or where to.. not intuitively at least. Also, I thought I VE tuner was part of the app but it looks like you have to have another app as well to use it.. or did I miss something?
THanks
GLen
Old May 6, 2016 | 10:05 AM
  #8473
adkg12's Avatar
adkg12
So I took the evening and AT'ed with 3, 20 minute in town rides, and 1 20 minute highway ride. Afterwards, I decided to compare the VE's that were generated to the STOCK tune. Sure enough, I was wrong...I was comparing the AT VE to the actual map I was tuning. Which apparently was too liberal. But when I compared the AT VE's to the STOCK tune, I found that the STOCK VE's were much much leaner than the AT ones.. I digress... Here is the tune, and a couple of logs..
Thanks..
Glen
File Type: zip
File Type: csv
Old May 6, 2016 | 10:06 PM
  #8474
LA_Dog's Avatar
LA_Dog
^ yup lots to ponder over. I just got done with a TT-AT tuning run today (57h cams, 50mm tb, 4.89 injectors). Big VE changes, chose scale when exporting changes and it set my engine CI to 119.1.
The base tune runs great, logs look good, even before TT-AT, so at this point I'm just experimenting with the AT to see what it wants to change in the overall tune.
Old May 8, 2016 | 05:21 PM
  #8475
LA_Dog's Avatar
LA_Dog
Tuning the new 57h cams, 50mm TB and 4.89 SE injectors has been going well. I'm kind of at a wall, not sure how to proceed due to lack of information on the topic beyond light discussion. My auto tune is wanting to scale or cap VE's - I tried scale at first and it set my engine CI from 103.3 to 119 and really dropped the VE numbers. I didn't like that so did not run with it. I ran another AT and elected to cap this time.
FRONT VE has 127.5 in several cells clustered together , 10-30TP and 2250-2750 rpm.
REAR VE has 127.5 in several cells clustered together, 15-25TP and 2750-3500rpm.
the rest of the VE's scale off lower, some around 123 or so in adjacent cells. a couple of my higher map / higher rpm cells are 125.
Bike itself runs very well, very fast, smooth on power delivery and not much knock activity. ET's good and after some slight tweaking of CDE tables my idle MAP is about 32kpa.
What say some of you experienced tuner folk- should I scale up the CI a bit to say 105-107 or drop the injector size from 4.89 to say 4.5? What's the best method to get my few maxed VE's down without affecting my present good power?
Old May 8, 2016 | 06:26 PM
  #8476
Wide Open Cycles's Avatar
Wide Open Cycles
Former Sponsor
Scale the CID's. It gives more room for adjustment.
Old May 8, 2016 | 06:41 PM
  #8477
LA_Dog's Avatar
LA_Dog
Thanks WOC- I'll bump it to 107 and take it for a spin. I have a pretty solid baseline to work forward from in any direction. Does changing CI only affect VE calcs or does it change other table params as well?
Old May 8, 2016 | 07:33 PM
  #8478
Wide Open Cycles
Former Sponsor
It just gives you more adjustment in the VE tables
Old May 8, 2016 | 07:52 PM
  #8479
LA_Dog's Avatar
LA_Dog
That got me a bit closer, setting CI to 107. I had two cells in the front VE table, 2500rpm 15,20TP 125.7 and 125.3. Everything else was lower but not overly drastic.
Oddly, AT asked me to scale or cap again and stated it detected VEs over 127. not the case though. I'll go back to my baseline tune and put in 109 this time.
Old May 8, 2016 | 08:37 PM
  #8480
Wide Open Cycles
Former Sponsor
Go up until you get the high ones closer to 120
