tailight problem
Old May 4, 2011 | 11:36 AM
joker66's Avatar
joker66
Default tailight problem
Just bought a 2011 flhrx and have less than 2500 miles on it. When I rolled into work yesterday a coworker told me my left tailight was out.The turn signal and brake light still work just the tail light is not illuminated. Any suggestions as to what to look for? Would this be covered under the warranty?
Old May 4, 2011 | 12:23 PM
TickTock's Avatar
TickTock
a burned out filament in the bulb. Have you checked it?
Old May 4, 2011 | 01:22 PM
joker66's Avatar
joker66
There is only one bulb and the turn signal and brake light functions work.
Old May 4, 2011 | 01:54 PM
TickTock's Avatar
TickTock
ok, so swap the left and the right bulb and see if it moves to the right side. If it does, then you need a new bulb. If not, post back here and let's see where it goes.
Old May 4, 2011 | 02:21 PM
UltraNutZ's Avatar
UltraNutZ
dual filament bulbs operate as such;
filament 1 (the one closest to the top of the bulb and stands higher) is for your brake and turn signal. filament 2 (the shorter of the two) is for run. so it is certainly possible that you have a filament in the bulb burnt and the other filamnet works fine which sounds like your case. Do what TickTock said and you'll find your issue.
Old May 4, 2011 | 02:40 PM
joker66's Avatar
joker66
filiments didn't look bad but I'll try it and see.
Old May 4, 2011 | 04:09 PM
joker66's Avatar
joker66
The bulb was bad even though there was no visable damage to the filament. Thanks for the help TickTock and UltraNutz, Learn something new every day. Got a pack of #1157 bulbs from Adavance auto.
Old May 4, 2011 | 04:41 PM
TickTock's Avatar
TickTock
Cool! Sometimes the simplest things to check end up being the problem.
Old May 5, 2011 | 06:24 AM
UltraNutZ's Avatar
UltraNutZ
i like simple! otherwise it gets complicated. Glad you got it fixed.
Robotech
Jun 10, 2019 09:12 PM
ryderbiker
Sep 21, 2015 04:12 PM
dnoishere
Oct 12, 2013 08:21 PM
gonzo3426
Aug 17, 2012 08:42 AM
Gary86
Jun 21, 2011 05:03 AM
