help with unknown electrical problem
Old Jul 16, 2005 | 10:34 PM
speedo's Avatar
speedo
Stage III
Default help with unknown electrical problem
Took my 99 xlh sportster for a ride today was running good.When I got home I shut it off to
open my garage door.Then got back on it turned the key and nothing happened I mean
nothing no lights at all I hit the start button and got nothing.Can anyone out there give
me some where to start.I've already had the battery checked and it's good.What next?
Speedo
Old Jul 16, 2005 | 10:37 PM
HDF Tech's Avatar
HDF Tech
Default RE: help with unknown electrical problem
Two things come to mind, bad battery connections, remove wire brush and replace the battery terminals or a bad main breaker.
Old Jul 16, 2005 | 11:05 PM
speedo's Avatar
speedo
Stage III
That is not the problem I checked the main circut breaker I even tried a new one but still
no luck. Bob
Old Jul 16, 2005 | 11:18 PM
papamonkey's Avatar
papamonkey
3rd Gear
If you are getting absolutly nothing, I would check to see if you are getting power to the ignition switch. Make sure you are getting good grounds at the battery and at the ignition switch.
Old Jul 16, 2005 | 11:22 PM
Johnny's Avatar
Johnny
The battery may be shot.
Old Jul 17, 2005 | 12:05 PM
HDF Tech's Avatar
HDF Tech
Don't rule out your ignition switch itself, you could dismount it and try to bridge the terminals on the back to see if it cranks over.
Old Jul 22, 2005 | 05:05 PM
zerbrick_1's Avatar
zerbrick_1
5th Gear
Speedo,
Have you found anything out? My 99 1200 has the same problem. I have yet to figure it out. I have gotten a lead on a possible problem. I have been told that the positive cable to the stater may be loose at the eyelet that bolts on to the starter.
I am checking mine tonight. Let me know if you find anything.
Thanks
Old Jul 22, 2005 | 05:50 PM
speedo's Avatar
speedo
Stage III
I found the problem. If your battery is good and you Main circuit breaker
is good.Check the 3 wires on the ignition with a light and if you don't get a light it is most likely the ignition itself.Also check starter positive cable
at starter with the check light before you do the ignition check.At least thats what was wrong with mine.Electrical is a bitch.Hope this helps.
speedo
http://adcache.cycletrader.com/5/5/2/79966552.htm
Old Jul 22, 2005 | 06:40 PM
HDF Tech's Avatar
HDF Tech
Glad you found the problem , they can be tough to trouble shoot sometimes, but usually with the process of elimination you can prevail.
Mr.Softy
11
May 22, 2015 12:58 PM
Sam316
Electrical/Lighting/Alarm
May 15, 2014 10:53 PM
mrbig381
Mar 25, 2012 05:00 PM
dmayer
Mar 4, 2011 07:21 PM
