Unstable Idle
Do you have a carb support bracket? If you grab hold of the air cleaner can you wiggle it up and down or side to side even a little?
What do you mean by "The head doesn't have any bolts"? There should be clamps with bolts between the heads and the intake, and between the heads and the exhausts.
Here is my note on checking for leaks ...
Intake And Exhaust Leaks Tests
You cannot get a good tuneup if there are intake leaks or exhaust leaks.
1. Check for Intake Leaks
With the engine idling spray WD-40 or propane gas around the carb/intake/cylinder head joints. WD-40 is said to work well because it has very fine spray droplets. Propane is best because it leaves no mess, and is most easily sucked in thru leaks. Be careful to not allow any of either to get sucked in thru the A/C.
Any change in engine RPM is a leak which must be fixed.
2. Check for Exhaust Leaks
Pour about 1/2 ounce of oil into each cylinder thru the spark plug holes. Run the engine at idle. You will get lots of smoke for about 5 minutes.
All smoke should come from the ends of the exhaust pipes/mufflers. Any other is a leak which must be fixed.
If the rubber bands are not detiorated, are neatly installed, and held in place with the clamp then with the support bracket there should be no leaks. These clamps should be installed when the heads are installed and tightened before the head bolts are tightened. For clamps the best are the T-bolt [aircraft style] clamps.
A/C usually means air cleaner. Sorry, i usually don't use these short forms.
I have not experienced this idle problem myself so i am going only by what i recall of what i have read on these forums. When i was working on a couple of Yamaha Virago projects some years ago slow return to idle was a common problem, the cause usually being that the two carbs were not synchronized. Hmmmm, here we have only one carb so that is out.
I would first ensure that there are no intake or exhaust leaks then check the ignition timing. Then i am at the end of my limited knowledge with this.
