Ironhead A place to talk about Ironheads.
73 ironhead rode hard seriously
Old Jun 28, 2006 | 11:48 AM
tattooedskin's Avatar
tattooedskin
3rd Gear
Default 73 ironhead rode hard seriously
Ok 4 yrs back bought a 1973 Ironhead. She ran good until now,,,,she is smokin bad on front cylinder and has a small jerk while in 2nd and 4th gear. Im think maybe just do a top end overhaul new pistons maybe 10 or 20 over. What do you think the skipping in the tranny is. What all should I replace on a Top End. From what I was told the bottom end on the Ironhead series is bulletproof is this correct? What carb is best for my 73.
Old Jun 28, 2006 | 12:05 PM
piniongear's Avatar
piniongear
Default RE: 73 ironhead rode hard seriously
Just what do you mean by 'small jerk' in 2nd and 4th?
As for the oil burning problem, you may have a scored piston as well as worn valve guides. A top end job including boring, new pistons and whatever the heads will require will fix that. You have to pull it apart first to determine what you are going to need.
Regarding a lower end being bulletproof; I do not think so. The rods have roller bearings and with proper lubrication these will run a good many miles. They do eventually wear out however.
Old Jun 28, 2006 | 12:20 PM
tattooedskin
3rd Gear
Well the jerk is almost like a slipping clutch but while your in gear.
Old Jun 28, 2006 | 12:38 PM
piniongear's Avatar
piniongear
Tat......you may want to pull the primary cover off and have a look inside. I do not know what could cause a 'slipping clutch' effect inside the transmission. What you find there is a broken tooth on a gear which leaves you with a constant clunking in that particular gear.
Inside the primary, make sure the engine compensating sprocket nut is tight and make sure the clutch hub is tight. These two items would affect the ride in all of the gears though, not just 2nd and 4th. So, I am at a loss as to what may be the cause of this.
Maybe another member has a suggestion.
Old Jul 26, 2006 | 05:48 PM
74_ironhead's Avatar
74_ironhead
are you lugging the tranny?
Old Aug 18, 2006 | 11:36 AM
76hdfxe's Avatar
76hdfxe
6th Gear
Sounds like a shift fork to me.
Old Aug 22, 2006 | 03:25 AM
sepixlh's Avatar
sepixlh
Hi I'm new in here, but to the point. Bended shift fork is also my bet. Good option for carb is change EVO's CV replacing your old wornout Keihin butterfly...
here is one
from my friends webpage
Old Aug 22, 2006 | 04:16 AM
74_ironhead
the cv is the way to go thats what I use
Old Aug 30, 2006 | 01:06 PM
Spectrexx's Avatar
Spectrexx
The old Sportys run better with an S&S carb. Set em and forget em. Best carbs for any bike, IMHO. Go to the All-Harley drags and you'll see that 99% of the bikes run them. They are a very simple design and are very reliable. I haven't had to touch mine in over 4 years.... still running great! I've used them on dozens of bikes and the performance and reliability can't be beat. The newer models are even better since they have an extra fuel circuit to tune.
As for the "slipping", I agree about the shifter forks. You can pull the tranny apart and rebuild it checking all the clearances while you are at it. It might need new shims, too. Just follow your FACTORY SERVICE MANUAL (not those crappy Haynes books) and it's an easy job.
Larry64
26
Oct 21, 2016 02:02 PM
blackhatguy
Jul 9, 2015 12:01 AM
twistdroach
Sep 17, 2014 08:09 AM
sniper77
Nov 1, 2009 09:40 AM
notbob
Sep 9, 2007 10:49 AM
