Ironhead A place to talk about Ironheads.
Complete electrical
Old Oct 20, 2009 | 12:51 PM
EvilWayz's Avatar
EvilWayz
Default Complete electrical
My mechanic has my service manual, and I'm looking for parts on Ebay. I'm basically trying to figure out what i need besides a wiring harness. i got an ignition coil and a genny, what else should I be hunting up?
Old Oct 20, 2009 | 03:09 PM
nwpaironhead's Avatar
nwpaironhead
Not sure about 'everything' but I could think of a few things. A voltage regulator, brake light switch, three 15 amp circuit breakers. If you're planning on running turn signals, you'll need a 2 pole flasher (old GM truck variety. electronic flasher if you choose l.e.d.'s) various light fixtures and bulbs, of course, and if you plan on making your own harness, I found a place on ebay that has 14 different colors of wire in 30 foot rolls for something like $70 and another place that has protective tubing
: Genuinedealz
bk-rider
:mrshosking
I couldn't seem to get the last link to post, so I just typed it.
Old Oct 20, 2009 | 03:15 PM
EvilWayz's Avatar
EvilWayz
In the Marines, if a vehicle is combat non operational by virtue of failing a limited technical inspection, it was referred to as deadlined. My nickname in the Marines was Deadline, as i could step on a vehicle and cause it to fail an LTI. no way in hell I'm fabricating my own wiring harness.
Old Oct 20, 2009 | 03:35 PM
nwpaironhead
Hey deadline!,
My sides are splitting. Thanks for the laugh. I'm sure you could do it, but if you would rather not, I did happen across a few harness' while I was working on that aspect. I think you'll want to go with a '73 or '74 harness. (think I saw one for under $100 a while ago) After that it looks like they change alot in the manual. There may be more years you could use, but I'm not sure.
Old Oct 20, 2009 | 05:41 PM
IronMick's Avatar
IronMick
Get a copy of the parts manual! And your own copy of the service manual.
Old Oct 20, 2009 | 06:15 PM
EvilWayz's Avatar
EvilWayz
My mechanic has my service manual, and I got outbid on the last parts manual i found.
Old Oct 23, 2009 | 03:02 PM
straydog13's Avatar
straydog13
theres no reason why you cant put together your own wiring harness.i am not an electrical guy at all either.use a 16 guage wire.also iwould use the electronic flasher as it flashes immediatly also i used new controls on mine and crossed the horn to the blinker hot wire so i didnot have to snake another wire throughthe bars.---it was a f up on my part that i corrected this way but if i were to do it again it would be the same.
halle77bobber
Ironhead
Feb 24, 2011 11:00 PM
renob
Oct 21, 2009 12:43 PM
SC-Longhair
Oct 14, 2008 12:39 PM
stevodigitalfly
Flathead
Jan 23, 2008 02:20 PM
wizardry68
Ironhead
Apr 16, 2007 04:09 AM
