Ironhead A place to talk about Ironheads.
need help .drains battry every 3 days.
Old Dec 26, 2006 | 03:12 AM
tattoobob's Avatar
tattoobob
Stage III
Default need help .drains battry every 3 days.
what do i check for whenmy battery does not last no more then 3 or so days.and it will not run now .i had to put a hot wire to the coil to get some wind.or can a just wire up a new harnsss.for my 79 xlh 1000.sprtyyy. i checked the gen.it was good.what do do.???????????
Old Dec 26, 2006 | 04:10 AM
panz4ever's Avatar
panz4ever
Default RE: need help .drains battry every 3 days.
tattoobob....check for a short somewhere in your system. Always start with the easy stuff first though. How old is your battery, short in ground wire, points, condenser, coil, coil wires, electrical system...lights, starting system, circuit breaker?
Old Dec 26, 2006 | 05:46 PM
pitbull1's Avatar
pitbull1
tattoo bob.One way to checkto see if you even havea direct short to test for is to removeonecable from the battery.Dosen't matter whick one just make sure the switch is off.Touch the cable back to the post and if you get any spark at all when the cable makes contact with the post you will know if you have current flowingwhich means youhaveflow fromthe batt(or a direct short).Be sure toflash the gen after you hook the batt back up.
Old Mar 17, 2007 | 12:18 PM
JsPop1's Avatar
JsPop1
6th Gear
tattoobob..........I had the same problem. What is your battery sitting on. Mine was straight on the steel tray so I put a piece of a car rubber inner tube in the battery tray, under the battery. That will help stop normal battery draw to the frame.
Old Mar 20, 2007 | 05:19 PM
Philly Stephan's Avatar
Philly Stephan
Have your battery tested. If it comes back good I would check your regulator.
Old Mar 20, 2007 | 06:17 PM
Oldtimer of NM's Avatar
Oldtimer of NM
If you try the spark test above and it shows you have something pulling current, take a look at the voltage regulator. I'm pretty sure they were still using the Bosch mechanical regulator in '79. If that's what you have, chances are the cutout relay is stuck closed. You can fix this by cleaning up the contacts with a points file, but it won't last as long as replacing the regulator. I you didn't get any spark, if you have a voltmeter (available cheap at radio shack and autoparts chains), check the voltage across the battery with the engine running. If it's less than 13 or more than 14.5 volts with the engine turning around 2000 rpm's, you have a charging problem. If this checks out OK, make sure the top of the battery is clean, as crud can bleed charge off to the battery cover. If this doesn't fix the problem, chances are the battery is about to go belly up.
Old Mar 20, 2007 | 06:36 PM
piniongear's Avatar
piniongear
I assume that you know you must always 'flash the fields' whenever you have had a battery wire disconnected? Failing to do so can result in the regulator points burning up......pg
Old Mar 21, 2007 | 06:37 PM
paintballoma's Avatar
paintballoma
whats flashing the fields???
Old Mar 24, 2007 | 10:16 AM
Scarletthehog's Avatar
Scarletthehog
tattoobob,
I had the same problem. I checked all the above things that were mentioned. I checked the charging system with the engine running and that checked out. Also, when I took one of the leads off the battery, there was no spark. What I did find was a direct ground, but it wasn't grounded all the time. Check the wiring where it makes sharp turns around the frame and fenders. I found my short where the stoplight wires went through the back fender going to the tail light. The wires had been rubbing on the fender and wore the insulation off the wire. I was able to get enough slack in the wire towrap it with electrical tape. That solved my problem!
Old Mar 26, 2007 | 06:56 PM
Shovelhead77's Avatar
Shovelhead77
ORIGINAL: paintballoma
This is when you run a jumper wire from your generator armature post momenteraly to you positive post on your battery. you do this to ensure proper charging.
rich56
Electrical/Lighting/Alarm
21
May 11, 2020 07:14 AM
Bill Bowen
Jul 9, 2016 09:54 PM
METALKAT
Nov 29, 2010 06:48 PM
trusty1
Oct 10, 2007 06:35 PM
chanhopark
Feb 10, 2007 11:00 PM
