M8 problems
Old Oct 21, 2017 | 09:42 AM
  #991
rodhotter's Avatar
rodhotter
sadly thru the years the engines got sloppier clearances as the prices continue to increase!! M-8 prolly the best ever design excepting the evo sporty IF it were built correctly with good parts, but some are lucky others not so much!!!! kinda like a hi-roller at the casinos!!!!
Old Oct 21, 2017 | 12:26 PM
  #992
jpooch00's Avatar
jpooch00
Originally Posted by yankees1996
Are you a pessimist ? Most of the riders I have spoken to or riders on the forum who have driven a 2018 were very impressed with the ride, power and they expressed that the total experience on a 2018 model was much improved ! I understand that there is a problem with the trans migration fluid on a few of the models ( not Softails) but I assume this problem will be worked out . I have never been a Harley rider/owner but very impressed with the Fat Boy and will take delivery in April 2018 !
Yep, 6 decades of seeing and hearing about their shenanigans has made me a dyed-in-the-wool pessimist thru & thru - when it comes to MoCo products.
So far, I haven't seen anything in these posts to make me alter that attitude, either.
Old Oct 21, 2017 | 12:29 PM
  #993
jpooch00's Avatar
jpooch00
Default Ya got that right!
I've known and said for many years that buying ANY MoCo product is a crap-shoot.
I bought my '15 Limited anyway. So far, at least, I think I got a good 'un.
Old Oct 21, 2017 | 03:08 PM
  #994
xnysgt's Avatar
xnysgt
There’s good news jpooch00, you can always pack your **** and leave. Wait, that’s right it’s a forum... so, you can always simply log off and join a Honda or Yamaha forum.
“6 decades” is a long time to be disappointed and whinny.
Old Oct 21, 2017 | 09:25 PM
  #995
2013superglideseattle's Avatar
Count me in for m8 problems. 2017 road glide special no engine mod at 14K.
First engine oil light came on at 9k, moco found engine oil migrating to primary chain case. They replace a seal, no more engine oil transfer.
Second at 12k miles, engine oil light illuminated again. Check dip stick and oil level at the middle, wtf! Took bike back to moco again and found a code about oil pressure sensor. They clear code and reset sensor connector.
Third, this time , my transmission oil dipstick showing no oil level anywhere at the dipstick. I can't believe my bike has transmission oil issue. My bike has no engine mod and rarely I run it at 3500rpm. But still my bike is not immune. I remember Harley bikes are notorious for an oil leak. This new designed engine M8, keep its oil inside. The oil doesn't get spit out anymore.
My bike is now approaching its 15k service. After reading at the other threads, moco has not yet develop a fix regarding this transmission oil issue.
In the meantime, I'll bring a quart of tranny oil with me on my trips.
One more thing, when people complement my bike at gas stops, I tell them thanks and also I'll make sure that they are aware of its issues.
If your m8 has no issues, lucky for you!
Old Oct 21, 2017 | 09:43 PM
  #996
Max Headflow's Avatar
Max Headflow
The oil light coming on is not indicative of tranny to primary xfer. Sounds like they didn't fix the problem.
Old Oct 21, 2017 | 10:19 PM
  #997
Bike has multiple issues. First oil light, engine oil to primary. They fixed it by changing a seal between chambers. Second oil light, oil pressure sensor issue. They disconnect and reconnect the oil pressure sensor wires. Some other owners here on the forum, they have the moco replaced the sensor altogether. I want them to do same but moco says if it comes back then they'll replace the sensor.
Unfortunately, there is no tranny oil light indicator. It would've illuminated on me.
Many thanks to this forum. M8 owners like myself gave me heads up on what to expect.
Old Oct 22, 2017 | 05:25 AM
  #998
Wizardofaus's Avatar
Wizardofaus
Different colors, same defects and problems, it seems.
In other words, business as usual at the good ol' MoCo.
Hang on Hang on Hang on....... 🤔
They changed to foot peg position on the 18 sporty didn't they 🤣
Gee Wiz 🙃
Old Oct 22, 2017 | 07:45 AM
  #999
yankees1996's Avatar
yankees1996
Maybe I'm wrong but I thought most of these engine/trans problems were isolated to the touring bikes with the hydraulic clutches ? The Softail with clutch cable trans were not having this trans fluid transfer ! Correct me if I'm wrong !
Old Oct 22, 2017 | 08:09 AM
  #1000
jpooch00's Avatar
jpooch00
Default Awww, now reality's pissed somebody off...
Whether the "Fanboyz" like it or not, what I said is still a fact.
BTW, I'm not disappointed at all. Low expectations from the get-go prevent that.
You should look into the "ignore" function in your user CP if what I have to say is so upsetting to you. It works great!
