M8 problems
Old Apr 21, 2018 | 02:25 PM
  #1331
northshore_paul's Avatar
northshore_paul
Originally Posted by F150HD
what is the actual mechanical solution to this problem?
I did read the service bulletin, but looking for a simple synopsis from someone experienced. Thanks.
From what I read in the extended service bulletin, it amounts to not riding long periods of time at high rpm's, (interstate speed) and check your oil frequently.
It reminds me of the joke about the guy who goes to the doctor and the doctor asks why is he here? He responds that when he turns his head to the far left it is very painful and the doctor responds, well don't turn your head to the far left and you should be ok. So with that logic, if you don't ride at high speeds on the interstate and check your oil level frequently it won't be a problem. I don't think that is a solution that today's customer will think is appropriate.
Old Apr 21, 2018 | 07:52 PM
  #1332
F150HD's Avatar
F150HD
if thats true thats ridiculous.!
Old Apr 21, 2018 | 08:06 PM
  #1333
northshore_paul
Here is the service bulletin link that a previous poster supplied.
https://www.hdforums.com/forum/attac...n-11_11_17.pdf (see bottom of page -2- through page -3-, later in the bulletin it advises the changeout of the oil pump if sumping is duplicated by dealer)
It tells the dealer to verify the problem exists, sumping, its causes and if it is able to be duplicated, then replace the oil pump. Now with a new oil pump do the same operating conditions result in the same problem? I don't know but maybe someone on the forum who has had their's replaced by this service bulletin can tell us.
Old Apr 22, 2018 | 07:26 AM
  #1334
F150HD's Avatar
F150HD
on a brief scan I recall the oil pump tidbit....but your point is true, does it fix the actual issue?
Kinda odd....the whole cam-tensioner problem in the TC88s early on....the upgraded cam plate assembly came w/ the 'new oil pump' everyone raved about. Is this the same oil pump that is 'failing' now and causing this issue? lol.....
Boy, you'd think HD putting the R&D $$ into a new engine like the M8 this stuff wouldn't be happening (?).
Thanks.
Old Apr 22, 2018 | 08:41 AM
  #1335
Max Headflow's Avatar
Max Headflow
Thanks.
Nothing wrong with the original TC oil pump.. The M8 pump is a slightly different design, still gerotor. IMO the problem isn't the oil pump itself.
Old Apr 22, 2018 | 08:46 AM
  #1336
F150HD's Avatar
F150HD
Thanks. I recall the new cam plate kit for TC88s coming with the new 'oil pump'....did not know what the M8 had.
Sounds like 'that' is not the solution to the sumping issue then despite the service buttetin.
So what would fix the issue? Thanks.
(I don't own an M8, just trying to learn about the engine)
https://www.shoputahharley.com/produ...YaAmX8EALw_wcB
Old Apr 22, 2018 | 09:05 AM
  #1337
northshore_paul
I had an EVO bagger without any problems. After selling it I was without a Harley for several years and during that time I was riding BMW bikes, (that have their own issues) and then came back to HD with a TC88. I was not aware of the tensioner problem then because I was not following the forums and did not do adequate research. Luckily the previous owner of my bike had the carb version so that is not an issue but the tensioner is. Until reading this thread I had been thinking of a new bagger because at my age I was really enjoying the ergonomics and laid back style of riding my Glide affords, compared to the Beemers. Now I will stick with what I have and wish I had my old EVO bagger. With evolution in nature we expect improvement and better adaptation/suitability to the environment, a concept lost on the MOCO.
Old Apr 22, 2018 | 09:17 AM
  #1338
Max Headflow
I suspect that HD came out with this pump to simply give the masses what they wanted, they already had what they needed. The biggest issue was that they put oil pressure gauges on the bikes.. HDs really don't need pressure, they need flow..
Old Apr 22, 2018 | 09:22 AM
  #1339
Heatwave's Avatar
Heatwave
Member
Actually they eliminated oil pressure readouts or gauges starting with the 2017 bikes.
Old Apr 22, 2018 | 10:02 AM
  #1340
mjwebb's Avatar
mjwebb
what is the definition of "High Rpms" and "for long periods of time "?
I mean I can get up to 80 easily in 3rd gear at about 5000 rpms which is below redline and rev limiter but that wouldn't be smart to set the cruise control at that point..LOL
