M8 problems
Old Jun 29, 2019 | 10:57 PM
  #1761
SluggoMagoo's Avatar
SluggoMagoo
Originally Posted by splattttttt
He says no issues.
I know with my twincam that if I over fill the primary, it shifts harder and neutral becomes difficult to find. Some report slip with this, but I’d assume it to be more evident with older worn out clutch disks.
And with most tranny to primary oil migration issues, there can be as much, or more than 8oz of lube missing from the tranny. Over the long term, wear is imminent to another wise area where it is almost non existent.
I just went over 5k on my 103TC. No issues. Drove it home tonight like I stole it and it was smooth through all 6 and the motor was pounding like two ****ers in rhythm. Time for a fluid change soon.
Old Jun 30, 2019 | 07:40 AM
  #1762
splattttttt's Avatar
splattttttt
TC have evolved well.And you can have one with a 110ci
Old Jun 30, 2019 | 11:29 AM
  #1763
JONNIEROCK's Avatar
JONNIEROCK
Originally Posted by skid_pimp
Well feel free to prove they knew it was malfunctioning when they sold it to you. Then go ahead and find a bunch of others that can too, you can all band together then and sue, and explain how put out you were by purchasing a mechanical thing with a fault. And how you deserve reparations for all your trouble. Let us know how it works out.
Wouldn't be to hard to prove, since most of them have the transfer problem, and if you don't have that problem now, you probably will eventually. Hey ! look at it this way, at least the dealer made out, now he can get paid for some repair work.
Old Jun 30, 2019 | 01:30 PM
  #1764
Supergo's Avatar
Supergo
Originally Posted by SluggoMagoo
Call Spitzies. See if you can get it vented.
My bike is there now. Hoping they take care of it under warranty.
Old Jun 30, 2019 | 02:15 PM
  #1765
Oldirty's Avatar
Oldirty
4th Gear
That's assuming he never checks his fluid levels ever too....
I do indeed check my levels. Usually only add 1/2 to 3/4 between 5k check up. Running synthetic oil.
Old Jun 30, 2019 | 04:08 PM
  #1766
jlombard's Avatar
jlombard
Where do you run your oil level at on the dipstick.
Old Jun 30, 2019 | 07:59 PM
  #1767
Oldirty's Avatar
Oldirty
4th Gear
I like to keep it full. No dots exposed.
Old Jul 1, 2019 | 07:33 AM
  #1768
skid_pimp's Avatar
skid_pimp
Most? Where or where did you get that interesting factoid?
Old Jul 1, 2019 | 08:42 AM
  #1769
splattttttt
Wow.
What was your last bike that you owned before you bought this one?
Old Jul 1, 2019 | 04:43 PM
  #1770
strych9's Avatar
strych9
I second this. I fill to full on changes and it doesn't drop at all between the 5K intervals. I run conventional oil, and have done so since my build.
