M8 problems
Old Mar 6, 2017 | 12:13 PM
  #411
ineversl33p's Avatar
ineversl33p
Originally Posted by Fairkid
Just about to go back to the dealer for third time with an oil leak at or near the base of the fwd push rod tube. 2800 miles...first showed up at 1k. Doesn't leak at town speeds, but after even 30 min on hwy the timing cover has drips and it's splashing back on some nice shiny chrome. Any one else hear of this? They've replaced the o-rings and base plate gasket twice now!
Could be blow by from the air cleaner?
Old Mar 6, 2017 | 12:17 PM
  #412
Fairkid's Avatar
Fairkid
Dealer says no....after running for a couple hrs on fwy...it's running down the timing cover....bit more than blow-by....wouldn't think there'd be any blow-by on a brand new engine anyway.
Old Mar 6, 2017 | 04:57 PM
  #413
Jackie Paper's Avatar
Jackie Paper
Actually, there will be more blowby on a brand new motor then one at 20k. However the airfilter box should catch it and hold it unless you have taken box off and have an exposed filter. Then it will drip on top of guide tube bases and at speed toward back. However if that is your problem, you can take a rag and wipe off bottom and back side of airfilter up about an inch and it will be oil wet. You need to wipe it down and drive and stop repeating till you see where its coming from. Could even be oil filter in the wind
Old Mar 6, 2017 | 05:10 PM
  #414
SWThomas's Avatar
SWThomas
Originally Posted by bwoltz
The biggest problem I've had with mine, is that the rear tire does not get enough traction in soft sand and buries the rear wheel to the mufflers. It took a couple guys to get me moving again..
Sorry, but why dafuq would you ride a touring bike in loose sand?
Old Mar 6, 2017 | 05:50 PM
  #415
sixguns's Avatar
sixguns
coupe years back while in Monument Valley, took a wrong turn on a side road looking for our cabin. spotted a dirt turn around and took it. Big surprise was the several inches deep of dry silt. Had the wife dismount the vehicle so I could dirt bike it. Good times!
Old Mar 6, 2017 | 06:08 PM
  #416
Max Headflow's Avatar
Max Headflow
It didn't look loose, There were tire marks on it that hadn't sunk. I figured it was OK.. If I'd been smarter I wouldn' have slowed down and simply headed beck to the road.
Old Mar 6, 2017 | 06:40 PM
  #417
SWThomas's Avatar
SWThomas
Right on. Just curious.
Old Mar 6, 2017 | 07:39 PM
  #418
Fairkid's Avatar
Fairkid
Thumbs up
Thanks! The first two rounds were clearly from the push rod tube...it's possible this one isn't, but quite a bit of oil after only a 60 mile run at hwy speed. We'll see....I love the bike thought....Hopefully, this round will let us know. for sure.
Old Mar 8, 2017 | 07:43 AM
  #419
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
code 0142 loss of comms to BCM... and they can't figure out why it's happening. They have it now for the forth time looking into this problem.
Old Mar 8, 2017 | 09:52 AM
  #420
Max Headflow
Did they replace the BCM?
