they said they put Synth3 on the transmission and primary ...? Why is that oil so stinky? I mean it smelled like burnt old oil! Tomorrow I'll change it before it boils my bike!
Boils your bike, is this a thing?
Don`t waste your money, you have fresh oil in the bike, leave it be, it is good for 5,000 miles.
$335.00 here in Tampa, and that is me providing engine oil (they refused to use 10/40 I had brought by mistake on my 2nd jug), but then they found I had moisture on my brake fluid and the flush cost me another $163.00...and they said they put Synth3 on the transmission and primary ...? Why is that oil so stinky? I mean it smelled like burnt old oil! Tomorrow I'll change it before it boils my bike!
Needless to say; I won't be taking my bike to the dealer for my oil changes, I only trust one person when it comes to oil changes...ME!
Prior to bringing the bike in for service, did you ask the Service department whether they were willing to use oil provided by you?
failed moisture content test at the 1000 mile service? did it sit outside a hurricane? was the cover loose, etc. if so they should have resealed with new gasket and tightened down good under warranty..$163 should have covered front and rear brake fluid flush so hope you got both for that $ charge and found out why it happened so new
