Cat less factory header
Old Aug 14, 2019 | 06:54 AM
  #41
DB44's Avatar
DB44
Stage I
[QUOTE=FLTRI17;15940898]I live in California and have over 5k on my RG since Sept and can say without reservation the heat from these engines and exhaust is night and day different (cooler) than my TC ever was.
Just my observation
Old Aug 14, 2019 | 07:31 AM
  #42
h7009's Avatar
h7009
Hey to all, Not sure if the new "cat" flows better or not, but it is just as hot. After removal get a "Heat gun" and measure the difference. I did it side by side with a friend, we went for a ride to coffee. Jumped off my bike got a reading, then went over and measured his, it was 125 degree difference. So again, not sure about flow...But heat loss is fantastic!! Your results may be different. Good luck, CSM-H
Old Aug 15, 2019 | 09:36 AM
  #43
hattitude's Avatar
hattitude
Originally Posted by FLTRI17
Anyone know how much performance is gained by removing the cat on these bikes?
Or is it just assumed the removal is worthwhile?
I believe the MOCO worked really hard to get the restriction down as much as possible.
Adding open mufflers to the stock header (with cat) provides a nice tone IMO.
Bob
My experience was with a twin cam engine and only a Stage II.... but I believe the effect of the CAT is pretty much the same between TC & M8...
I believe there are very little performance gains, just loss of heat and sound changes......
When I was modding my '12 limited, I got it from the dealer with a Stage II (SE A/C, SE Mufflers, & SE255 cams). I had a cross country trip planned and wanted to keep the warranty intact. It had an HD Stage II tune.
After the trip, and towards the end of the warranty period, I bought a PV tuner from FuelMoto. They sent me the tune for my mufflers & air cleaner (stage II). I told them I would be buying their 2-1-2 head pipe within a couple months, and asked if I should get another tune at that time. FuelMoto told me that when I added their head pipe, I wouldn't need to change the tune, because the CATS flow really well...
When I added the 2-1-2 head pipe, I ran an auto tune and the 1st 20 minute session only had 4% average change.... That is the amount of change they say you should work to, when auto tuning.... so there truly was little difference between CAT and no CAT, in the VE tables....
thunderroad1
Engine Mechanical Topics
Apr 8, 2014 09:52 AM
WRAITH
Nov 28, 2012 09:13 AM
pigjockey
Nov 26, 2011 01:08 PM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
14
Jan 28, 2011 02:11 PM
steel insane
Jan 27, 2008 10:47 AM
