Installing de-catted head pipes
Old May 1, 2019 | 01:53 PM
jimvall's Avatar
jimvall
I purchased an OEM de-catted head pipe on EBAY, then re-installed the S&S MK45 slip ons I had on before. The sound is now definitely much better. Not loud but very throaty with a very healthy rumble upon accel and decel.
Old May 2, 2019 | 08:53 AM
Bumpandrun's Avatar
Bumpandrun
Also decatted a few and used fullsac baffles in cvo cans only....bikes ran fine and are still doing good. 2 even slid thru warranty never to be found. ( we cut along stock factory weld.remove and port re tig weld on factory seam looks factory)Plugs look good and less heat on passenger. All on touring head pipes. Sound ? Not much different .....performance? Not real noticeable.....big deal is heat.
Old May 3, 2019 | 04:46 PM
GliderXXX's Avatar
GliderXXX
So you're basically still running the 2-1-2 just minus the cat right? At first I thought you were asking about true duals and a straight 2-2 system. I can't imagine not needing a tune for that if for no other reason than to not lose a ton of low end.
Old Jun 3, 2019 | 06:22 PM
invisusAG's Avatar
invisusAG
Stage I
Hey, I’m running the same setup. I’m curious did you do the dB reducers in or out? Both sound okay, there’s a pretty noticeable blatty sound on decel and accel. Thanks!
Old Jun 3, 2019 | 06:33 PM
Gary1's Avatar
Gary1
Dyno results tell us there isn't any performance gains by decatting a M8. So why?
Old Jun 3, 2019 | 07:53 PM
AFSOC_Commando's Avatar
AFSOC_Commando
As previously mentioned HEAT...
I replaced mine at 2 years with the SuperTrapp Unfiltered Header and the heat is about gone from the exhaust and the bike has more bark under hard throttle.
I ride.. A LOT and the reduced heat, especially in traffic is so much more comfortable. No different then changing the seat for comfort.
Old Jun 4, 2019 | 05:15 AM
rdc401's Avatar
rdc401
Originally Posted by mjwebb
guess I'm a little bit surprised doing this wouldn't spit out a code from 02 readings...????..but hey, if there's no harm then no foul!
The cat is After the 02 sensors,so it will run fine.
dshelly
The Dyno Room
Apr 12, 2017 07:08 PM
jrider62
Aug 26, 2015 02:56 AM
joenash
2014-2024 Touring Models
22
May 21, 2015 02:49 PM
samk9lover
Aug 29, 2013 07:20 PM
1bad09sglide
Jul 23, 2010 09:18 PM
