2023.5 CVO 121 changes
I seriously doubt all this new to Harley technology will do even close to 1hp per cu.in still and that's pitiful.
In fact as I understand it a 9.4% increase over the 117 which Is 94hp or .80 per cu.in.. Add another 9.5hp but 4cu.in. as well is a dismal 103 - 104hp for 121cu.in.. or .85 per.
Now factor in extra weight for all this added bs and you're !lucky to not be losing power. No thanks.
These numbers are at the crank btw..and it's still falls short of 1 per!
If a cannibal used a fork some would call that progress I guess. Fast my ***.
All this bs is for one reason...emissions...they have no choice. Milwaukee-Eight VVT 121 Specs
- Displacement: 121 cubic inches (1977cc)
- Bore x Stroke: 4.075″ x 4.625″
- Compression Ratio: 11.4:1
- Fuel Octane Recommendation: 91
- Torque: 139 lb. ft. (189 Nm) torque at 3000 RPM
- Horsepower: 115 horsepower (86 kW) at 4500 RPM
If the moco were just targeting people like like you with this new 121 CVO VVT engine, more power to you(pun intended) but that would be foolish. There are more potential buyers who are like me than you think. Personally I'm not one of them. I'm quite content embarrassing people like you foolish enough to pull up next to me at a light.with their stock M8 and give me that stupid look I've seen so many times.
The look on their faces down the road or at the next stop is priceless when they look at my bike and see the 103 still on the primary cover. That's if they stop at all. More times than not they just keep going.
Maybe next year when I retire I will tour. If and when I do I will probably trike my TC Heritage..Just as it is.. 110ft.lbs. and up from 2200 to 6000rpm. is all I need and I'm geared for it.
That's your peak torque btw. It occurs very briefly @ 3000rpm and drops like a rock on both sides. And you call that good usable power too. You'd probably **** yourself on my ancient TC.
The numbers of the Stage 3 122 are pretty close to what this 121 will be only it will hang on to the torque a little better as the peak hp will hit 500 rpm sooner tho.
The v-twin has hit the end of the road in terms of power and EPA compliance. Lest you forget you could do 80hp with a TC 103 with a good pipe and a tune. That's .77hp per cu.in.
Over 10 years later and we have an M8 121 with VVT that does a whopping .08HP per cu.in. more?
GO AWAY.
Oh, and if you ever do bring your little piece of **** west...I'm your Huckleberry
