Oil Archive (no new posts) An archive of oil related questions and comments.
TC Oil Change, how much oil
Old Dec 3, 2007 | 07:55 PM
Deus Ex Machina's Avatar
Deus Ex Machina
Default TC Oil Change, how much oil
I need to know how much for each hole on a TC motor. I don't own one or I would know already .. TIA.
Old Dec 4, 2007 | 03:05 AM
BadPiggy's Avatar
BadPiggy
Default RE: TC Oil Change, how much oil
Well, I'll tell ya...
I usually fill mine to the FULL mark...but to narrow that down a bit...
On Softtail models the oil is usually 3 qts...Touring models, 3.5 qts.
Primary is a full qt.
Trans, between 20-24 ozs...except on '07 and up models, they get a full qt.
The trans is checked with the bike upright.
The oil is checked on the stand.
Old Dec 4, 2007 | 04:37 AM
WildBill2566's Avatar
WildBill2566
It will I think depend on which model and sometimes even which year.
I can only give you the volumes for an 07 RK Classic.
Engine......................... Dry change = 3.8 litres Wet (normal drain with filter) = 3.3 litres
Gearbox (tranny)........... Dry or Wetchange = 0.946 litres (I think thats about a quart)
Primary ....................... Dry = 1.33 litres Wet= 1.12 litres
Above data direct from the HD manual
WB
Old Dec 4, 2007 | 07:20 PM
1flhtk4me's Avatar
1flhtk4me
Engine is about 3.5-4 qts w/filter.
Primary is about 32-38 ozs.
Tranny is about 22-24 ozs.
This is what i run in my 06 Road Glide.
Old Dec 4, 2007 | 07:50 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My TC88 takes 2.5 qts on a wet change. 3.0qts if the engine is bone dry like a rebuild. My 6 speed trans takes 1 qt. My primary takes 1 qt. That is a 2006 FXDLI.
Old Dec 5, 2007 | 02:31 PM
EZ2Rider's Avatar
EZ2Rider
On Dynas, 3qts. total capacity, add 2 1/2 after drain and warm to full operating temp and bring level to full on dipstick OR just fill cold to half way between full and add and check after next ride.
On Touring bikes, 4qts. total capacity, same proceedure just use 3 1/2 for a cold fill.
B motors (softails) are less but I am not familiar enough to say how much.
A motor 5 speeds take 22-24 oz. of trans fluid (gear oil) and the primarys take a quart, give or take an oz or a few depending on who you ask. A qt. is what I use on my 06 Roadglide and used for 20K on my 04 Wideglide with no ill results. Just drained and dumped it in the primary inspection cover. Some will say its not enough and you should remove the derby and fill to the bottom of the clutch basket, no harm in it but I don't PERSONALLY think its necessary. Your paranoia may vary![sm=grinangel.gif]
Note, six speed dynas take a full qt. of transoil, not 22-24 oz as earlier 5speed versions did and some dynas manuals call for LESS than a qt. in theprimary. This was to alleviate clutch drag which could be a problem with some year models. HDs solution ? Lower the recommended primary oil level which lessens or eliminates the drag. Strange but true!
Old Dec 12, 2007 | 12:48 AM
PosseRider's Avatar
PosseRider
Different models take diff capacities
Old Dec 12, 2007 | 08:20 AM
Deus Ex Machina
Thanks for all the replies folks. I needed to know cause at my recent HOG Christmas party we had a White Elephant gift exchange and mine was a Oil change, four qts of Mobile1. I am about the only Evo in the group, most being TC's, hence the question. Thanks again, no more replies needed.
Lee
Old Dec 12, 2007 | 01:26 PM
glide's Avatar
glide
ORIGINAL: BadPiggy
The 07 touring gets 38 ounces. (quart + 6 oz)
If in doubt , fill it to the bottom of the clutch basket only.
2007ELECTRICGLIDE
May 14, 2010 11:11 AM
mhud
Mar 21, 2008 06:17 PM
John3:16
Aug 2, 2007 09:40 PM
gammong
May 20, 2007 03:18 AM
lostrider06
Aug 14, 2006 02:56 AM
