HD newbie
I drained 2 plugs on my 2010 Road King. The forward facing one is the engine oil and the bottom facing one is the transmission, correct?
The engine oil dipstick show empty after I drained the engine, and the allen dipstick next to the engine oil is the trans I thought...Well, it shows there is some oil in there still- is that normal? It also looks very clean, where the oil drained from the bottom was dirty. What am I missing? The pictures I have seen online show people re-filling the trans from the cover on the left side. Is this normal practice or do people re-fill from the dipstick? Is that cover even for the trans? In sportbikes It is all one oil from the clutch, trans, and engine with one plug and one fill.
Sorry for what seems like simple answers, but I am a bit confused by this beast.
I have read 20/50 for the engine oil and 75/90 for the trans oil, correct?
thanks for the help!
Remove the derby cover bolts (with the correct tors bit) before draining the primary. If you snap one of the little bolts, they're a bugger to get out.
The primary is filled through the side cover (aka derby cover) and that requires a wet-clutch compatible oil in the 10w40 to 20w50 range (some even use ATF).
Hope that helps...
I have read 20/50 for the engine oil and 75/90 for the trans oil, correct?..
Hope that helps...
Thanks so much for the help.
The other external hex (also 5/8's) near the rear and facing straight down drains the transmission. It also contains an o-ring making same statement above apply.
As the tranny fluid can last a long time...change it the first time with a good gear oil (75w140 is ok) and be done with it for another 10,000 miles.
NOTE: when changing the motor oil, not all of it will drain out leaving as much as 1 quart remaining. When refilling with fresh oil, add one qt at a time checking often. Over filling will cause some issues including oil being forced out the air cleaner and making a great mess. Many find leaving the "HOT" level at the lower end of the stick helps oil bypass problems.
Normally the primary fluid is added through the derby cover with the bike upright. Just add the appropriate amount (usually a quart plus a few ounces) and you'll be good to go. Don't twist the cover gasket or it will leak.
Hope that helps!
Little over a quart into the primary and I Think almost 3 went into the engine. Came out perfect after running. Right in the middle of the hot operating. Thanks for the help again, who woulda thought there would be so many place to fill on a bike lol.
